February 23, 2020, 04:01:02 am
Next steps to be coded
Started by Paul Squires, December 29, 2007, 11:59:00 am
OK, the changes have been made. I will spend the rest of the night doing some testing. I will then put together a source code package tomorrow or Tuesday and post it for everyone else to take a look at. So far, the server weighs in at 55K and the client at 37K.
Here are the changes:
- User names and passwords are now checked by the server during sql3_connect. %ERR_BADUSER is returned if invalid user.
- Changed the server's initialization from an SQLite database to a simple text ini file (sql3server.ini).
- Server can now listen to multiple IP addresses.
- The server main screen now shows the IP address and port number of the server.
- Linked lists are now used to hold Connections, IP Addresses, Users and row cache.
- Column numbers are now zero based. To iterate the column names use For x = 0 to NumCols - 1
- Re-wrote all of the recordset functions. Of particular note is sql3_rsFetch.
