April 16, 2021, 07:35:56 AM
SQLite3 C/S 0008 (February 1, 2008)
Started by Paul Squires, February 01, 2008, 10:53:47 PM
Everything you need to know about using the code is in the "sample.bas" code file.
Here is the download link: http://www.planetsquires.com/files/sql3_cs_0008.zip
Version 0008 (2008-02-01)
- Updated Sqlite3.dll to version 3.5.5
- Changed sql3_rsColText, sql3_rsColInt, sql3_rsColInt64 to allow the column name to be passed rather than the column
number. Specifying the column name overrides any column number in the function call.
- Fixed SELECT * queries to return RowID as column 0. This problem only occured when SELECT * queries were run in %SQL3_REMOTE mode.
