February 27, 2020, 04:52:13 am
SQLite3 Client/Server Tips & Tricks
Started by Paul Squires, February 11, 2008, 08:19:07 pm
February 11, 2008, 08:19:07 pm Last Edit: June 29, 2008, 07:42:13 pm by TechSupport
I have spoken to a few people regarding the use of the SQLite3 Client/Server code and many lament that it is slow in client/server "remote" mode when sending a bulk number of individual INSERT or UPDATE commands to the server. The reason for this is that there is an overhead associated with the setup and TCP call to the server. A much better and significantly faster method is to create a dynamic string locally containing many individual SQL commands and send them all at one time to the server (wrapping the entire string of commands in a TRANSACTION).
Here is actual code from FireFly3's code snippet handler that inserts or updates code in the SQLite database. It iterates a linked list and builds a large SQL string composed of many individual SQL commands. After the loop ends, the SQL string is wrapped in a transaction.
(Note: This code uses a "local" database. If used in a client/server "remote" environment then you would need to issue an sql3_connect just after creating the session).
   sDatabase = GetDataStore & $CODESTORE_FILE
   If Dir$( sDatabase ) = "" Then Exit Function
   sql3_StartSession hSession, 0   ' do not use Unicode support
   errcode = sql3_Use( hSession, sDatabase, %SQL3_LOCAL )
   If errcode Then GoTo ExitOut
   pListItem = List_GetFirst( g.pListSnippets )
   Do Until pListItem = 0
      List_GetItemInfo pListItem, "", pSnippet
      If pSnippet Then
         If @pSnippet.IsDirty Then
            fChanges = %TRUE
            If @pSnippet.nRowID = 0 Then
               sSQL = sSQL & "INSERT INTO Snippets (name, code) VALUES ( '" & _
                             sql3_Fix(@pSnippet.@zName) & "', '" & _
                             sql3_Fix(@pSnippet.@zCode) & "' );"
            Else
               sSQL = sSQL & "UPDATE Snippets SET name = '" & sql3_Fix(@pSnippet.@zName) & "', " & _
                             "code = '" & sql3_Fix(@pSnippet.@zCode) & "' WHERE rowid = " & Format$(@pSnippet.nRowID) & ";"
      pListItem = List_GetNext( pListItem )
   Loop
ExitOut:
   If fChanges Then
      sSQL = "BEGIN IMMEDIATE TRANSACTION; " & _
              sSQL & _
             "COMMIT TRANSACTION;"
      errcode = sql3_Exec( hSession, sSQL )
   If hSession Then
      sql3_EndSession hSession
I hope that this little tidbit of information helps you.
How to get the number of rows returned from a SELECT query. You need to use the COUNT function as part of your SELECT.
Example:
sSQL = "SELECT COUNT(RowID) AS RowCount FROM dvd;"
   If sql3_select( hSession, sSQL, rs, 1 ) = 0 Then
      If sql3_rsFetch( hSession, rs ) <> %SQL3_EOF Then
         MsgBox "RowCount: " & sql3_rsColText( hSession, rs, "RowCount", 0 )
   If rs Then sql3_rsDestroy hSession, rs
As you can see, the COUNT is aliased as RowCount so you can get the value using the sql3_rsColText or sql3_rsColInt. If you need to know the number columns returned in a query recordset then use the sql3_rsColCount function.
