February 23, 2020, 03:41:46 am
How many record
Started by Robert Sarrazin, March 01, 2008, 12:45:09 am
Robert Sarrazin
March 01, 2008, 12:45:09 am Last Edit: March 01, 2008, 01:42:04 am by Robert Sarrazin
Hi,
I try to figure out how many record or ROW in the data base.
This is the File:
using SQLite version 0009
                 sSQL = "CREATE TABLE [dvd] ( "   & _
                        "[num] INTEGER PRIMARY KEY, "  & _
                        "[titre] CHARACTER (30), "          & _
                        "[acteur] CHARACTER (25), "          & _
                        "[lang] NUMERIC, "         & _
                        "[form] NUMERIC, "        & _
                        "[type] CHARACTER (8 ), "          & _
                        "[image] CHARACTER (12), "          & _
                        "[comment] CHARACTER (20)" & _
                        errcode = sql3_exec( hSession, sSQL )
the num is my key
I try this.
test1       x = sql3_rsColCount( hSession, rs ) ' THAT WORK OK GIVE BACK Column NUMBER
              x = sql3_rsRowCount( hSession, rs ) ' OPP Missing declaration: SQL3_RSROWCOUNT
test 2      sSQL = "SELECT * FROM dvd WHERE " + "max(num)"+ ";"
test 3      sSQL= "SELECT MAX(num) FROM dvd;"
test 4      sSQL= "select COUNT(*) from dvd;"
test 5      sSQL = "SELECT count(num) FROM dvd;"
              errcode = sql3_select( hSession, sSQL, rs, 1000 )
              DO UNTIL sql3_rsFetch( hSession, rs ) = %SQL3_EOF
                    x= sql3_rsColInt( hSession, rs, "num", 0 ))
              LOOP
              MSGBOX STR$(x)
I got the result now by reading with select like %% that read
record by record to the end of the file and I got the last record ( num ).
I try to find a better way to program that.
Thank for your time. ::)
I think that you are on the right track. Here is an easy way to get the record count:
   sSQL = "SELECT COUNT(RowID) AS RowCount FROM dvd;"
   If sql3_select( hSession, sSQL, rs, 1 ) = 0 Then
      If sql3_rsFetch( hSession, rs ) <> %SQL3_EOF Then
         MsgBox "RowCount: " & sql3_rsColText( hSession, rs, "RowCount", 0 )
   If rs Then sql3_rsDestroy hSession, rs
