May 31, 2020, 04:17:21 pm
Get all tables (does this work for you?)
Started by mikedoty, November 05, 2008, 12:51:27 pm
mikedoty
November 05, 2008, 12:51:27 pm Last Edit: November 05, 2008, 12:55:06 pm by Mike D
SELECT name FROM
(SELECT * FROM sqlite_master UNION ALL
    SELECT * FROM sqlite_temp_master)
      WHERE type='table'
        ORDER BY name;
When I execute this I get no error, but no record set.
While at it, does anyone have a SQL statement that displays all tables
with all column names (and why not indexes) for extra credit?
Fred Meier
This rut will put all tables, columns, indexes, triggers, and views to a flat file.
You won't be able to compile because of the calls to my private ruts but you will get the idea.
Function MapIt() as Long
   Local llDo, llDo2 as Long
   Local llA, llB as Long
   Local llInWord as Long
   Local llFlag as Long
   Local lsA as String
   Local lsTableName as String
   Local lsSql as String
   Local lsColumn as String
   Local lsColumnName as String
   Local lsColumnAttributes as String
   Local lsColumnComments as String
   Local lsColumns as String
   ' Init stuff
   axLoadLib "axBlue"
   print# glMapFileNumber, string$(80, "=")
   print# glMapFileNumber, "Mapped on " & date$ & " at " & time$ & " for Database " & gsDatabaseName
   ' Process each table
   slSel "Select tbl_name,sql from sqlite_master where type='table'
   do while slGetRow
      ' Save names
      lsTableName = slFN("tbl_name")
      lsSql = axReplace(slFN("sql"), $CRLF, "  ", "A")
      llFlag = %False
      ' Head it
      print# glMapFileNumber, arBuildSectionHeader(slFN("tbl_name"))
      lsA = lsSql
      arSplitText lsA, 80
      for llDo = 1 to axParseCount(lsA, $WrdMrk)
         print# glMapFileNumber, space$(3) & parse$(lsA, $WrdMrk, llDo)
      next
      print# glMapFileNumber, ""
      ' Find start of columns and save it
      regexpr " *" & lsTableName & "[ '""]*\(" in lsSql to llA, llB
      if isfalse llA then
         print# glMapFileNumber, "Can't find table name followed by (."
         iterate do
      lsColumns = rtrim$(mid$(lsSql, llA + llB))
      ' Remove trailing )
      if right$(lsColumns, 1) = ")" then
         lsColumns = trim$(left$(lsColumns, -1))
      else
         print# glMapFileNumber, "Create doesn't end with )."
         iterate do
      ' Comvert column commas to $WrdMrks
      for llDo = 1 to len(lsColumns)
         select case const$ mid$(lsColumns, llDo, 1)
         case ","
            if isfalse llInWord then mid$(lsColumns, llDo, 1) = $WrdMrk
         case "[", "]", "'", "(", ")"
            llInWord = llInWord xor 1
         case "/", "*"
            select case const$ mid$(lsColumns, llDo, 2)
            case "/*", "*/"
            end select
         end select
      next
      ' Print each column
      print# glMapFileNumber, space$(3) & "==========>>> Columns"
      for llDo = 1 to axParseCount(lsColumns, $WrdMrk)
         lsColumn = ltrim$(parse$(lsColumns, $WrdMrk, llDo))
         ' Check for ending constraints
         regexpr "(unique)|(primary key) *\(" in lsColumn to llA
         if llA then
            if isfalse llFlag then
               llFlag = %True
               print# glMapFileNumber, space$(3) & "==========>>> Constraints"
            print# glMapFileNumber, space$(6) & lsColumn
            iterate for
          ' Build column name and attributes
         if left$(lsColumn, 1) = "[" then
            lsColumnName = mid$(lsColumn, 2, instr(mid$(lsColumn, 2), "]") - 1)
            lsColumnAttributes = ltrim$(mid$(lsColumn, len(lsColumnName) + 3))
         elseif left$(lsColumn, 1) = """" then
            lsColumnName = mid$(lsColumn, 2, instr(mid$(lsColumn, 2), """") - 1)
         else
            lsColumnName = parse$(lsColumn, " ", 1)
            lsColumnAttributes = ltrim$(mid$(lsColumn, len(lsColumnName) + 1))
         ' Seperate any comments within the attribures
         lsColumnComments = parse$(parse$(lsColumnAttributes, "/*", 2), "*/", 1)
         arSplitText lsColumnComments, 52
         lsColumnAttributes = parse$(lsColumnAttributes, "/*", 1) & parse$(lsColumnAttributes, "*/", 2)
         ' Move first line of comments to attributes if there are no attributes
         if isfalse len(lsColumnAttributes) then
            lsColumnAttributes = parse$(lsColumnComments, $WrdMrk, 1)
            axParseDelete lsColumnComments, 1, $WrdMrk, "W"
         ' Print it
         print# glMapFileNumber, space$(6) & iif$(len(lsColumnName) > 25, lsColumnName, axJustStr(lsColumnName, -25)) & " " & lsColumnAttributes
         for llDo2 = 1 to axParseCount(lsColumnComments, $WrdMrk)
            print# glMapFileNumber, space$(31) & " " & parse$(lsColumnComments, $WrdMrk, llDo2)
         next
      next
      slSel "Select * from sqlite_master where upper(tbl_name)='" & ucase$(slFN("tbl_name")) & "' and type='index'", 1
      do while slGetRow(1)
      ' Process indexes for this table
      llFlag = %False
      slSel "Select type,sql from sqlite_master where upper(tbl_name)='" & ucase$(slFN("tbl_name")) & "' and type='index'", 1
         if len(slFN("sql", 1)) then
               llFlag = %True
               print# glMapFileNumber, space$(3) & "==========>>> Indexes"
            print# glMapFileNumber, space$(6) & slFN("sql", 1)
      ' Process triggers for this table
      llFlag = %False
      slSel "Select type,sql from sqlite_master where upper(tbl_name)='" & ucase$(slFN("tbl_name")) & "' and type='trigger'", 1
            llFlag = %True
            print# glMapFileNumber, space$(3) & "==========>>> Triggers"
   ' Process views
   llFlag = 0
   slSel "Select name,tbl_name,sql from sqlite_master where type='view'
   do while slGetRow
         llFlag = %True
         print# glMapFileNumber, arBuildSectionHeader("Views")
      print# glMapFileNumber, space$(6) & slFN("sql")
   ' Exit OK
   function = %True
