May 26, 2019, 04:31:51 am
How do I create a table if it does not exist?
Started by Andrew Lindsay, June 29, 2009, 10:32:00 am
Andrew Lindsay
I am connecting to a database and I do not know if there is a table present, how do I check if a table is present, and if not, create it?
I tried "If Not Exists FooBar Create FooBar ( Column1 TEXT, Column2 TEXT );"
Any asistance would be appreciated.
Regards
Andrew
Fred Meier
Hello Andrew,
check ExampleB.bas. Here you find the proper syntax:
slExe "Create Table If Not Exists T1 (F1, F2)"
You forgot the "Table" keyword and the order of commands should be different.
Quotetried "If Not Exists FooBar Create FooBar ( Column1 TEXT, Column2 TEXT );"
Correct would be:
"Create Table FooBar If Not Exists ( Column1 TEXT, Column2 TEXT );"
Rolf
www.rbsoft.eu
Andrew Lindsay
Thanks all kindly.
That has solved it perfectly.
Regards
Andrew
