September 23, 2020, 12:50:55 am
Database Navigation with SQLitening
Started by Rolf Brandt, June 30, 2009, 12:15:45 pm
Gafny Jacob
The attached zip file seems to be corrupt, can someone please mail me a good one. Thx
Hello Jacob,
I reuploaded the zip file. Should work now.
Rolf
www.rbsoft.eu
If there are duplicates in a column wouldn't the previous and next always get the same record?
IF TRIM$(SearchTxt) = "" THEN
    SELECT CASE Direction
      CASE "<<"
        t1 = ""
        t2 = " LIMIT 1"
      CASE "<"
        T1 = " AND " & SrtFld & " " & direction & " '" & RecVal & "'"
        t2 = " DESC LIMIT 1"
      CASE ">"
        t1 = " AND " & SrtFld & " " & direction & " '" & RecVal & "'"
        t2 = " LIMIT 1"
      CASE ">>"
        t1 = ""
      CASE ELSE
    t = "SELECT " & Flds & " FROM " & Tbl & " WHERE "   & WhereStr & _
      t1 & " ORDER BY " & SrtFld & t2
    IF TRIM$(WhereStr) = "" THEN
      t = t & SrtFld & " LIKE '%" & SearchTxt & "%' LIMIT 1"
      t = t & WhereStr &" AND " & SrtFld & " LIKE '%" & SearchTxt & "%' LIMIT 1"
CJ - you are perfectly correct! Have to make some changes to it.
rb
www.rbsoft.eu
July 09, 2014, 11:09:25 am #20 Last Edit: July 09, 2014, 03:08:44 pm by cj
Not sure if SQLite added cursors.  See some examples using them on the net.
This thread is about not using them and using slSelAry instead.
http://www.sqlitening.com/support/index.php?topic=2636.0
--FIRST and LAST is easy, but previous and next?
--column + rowid search needs to be worked out for previous and next?
create table if not exists t1(f1 integer primary key autoincrement, f2);
create index if not exists index_name on t1 (f2);
-- Insert 'A' 3-times into column f2
insert into t1 (f1,f2) values (null,'A'),(null,'A'),(null,'A');
-- (get last) order by f2,f1 so descending if no index;
select 'LAST ' ,f2,rowid from t1 order by f2,f1 desc LIMIT 1;
-- (get first);
select 'FIRST' ,f2,rowid from t1 order by f2 ASC LIMIT 1;
results:
LAST   A  3
FIRST  A  1
