September 16, 2021, 11:21:18 PM
How do I find and Delete Duplicates?
Started by Andrew Lindsay, November 28, 2009, 04:56:11 AM
Andrew Lindsay
I have a table that has a DateTime field and an Integer field.  I want to I have imported (approximately) 4 GB of CSV text into the database, but now find that there are a considerable (maybe 30%) of duplicates.  I would like to know if there is a way to find and delete duplicate data (based on the DateTime record).
Best regards
Andrew Lindsay
Fred Meier
November 28, 2009, 04:41:58 PM #1 Last Edit: November 28, 2009, 11:37:39 PM by TechSupport
Here is one way
   Local lsPriorDateTime as String
   slOpen "Database FileName.Sld"
   slExe "Begin"
   slSel "Select DateTime, RowID from TableA Order by DateTime"
   do while slGetRow
      if slFN("DateTime") = lsPriorDateTime then
         slExe "Delete from TableA where RowID=" & slFN("RowID")
      else
         lsPriorDateTime = slFN("DateTime")
   slExe "End"
EDIT: By Paul Squires (I can't seem to post a reply so I am modifying Fred's post)
Maybe something along the lines like described in this post:
http://stackoverflow.com/questions/1173963/delete-duplicate-rows-from-sqlite
DELETE FROM table WHERE rowid NOT IN
    (SELECT MAX(rowid) FROM table GROUP BY date);
