August 23, 2019, 06:13:58 am
SQL (Hopefully) question
Started by Andrew Lindsay, December 01, 2009, 08:29:00 pm
Andrew Lindsay
Greetings again,
I have a table that has the following set-up
RecordTime DATETIME,
extTens1 INTEGER,
Pitch1 REAL,
Pitch2 REAL,
Pitch3 REAL,
Roll1 REAL,....
The RecordTime is set as a unique key and index, and the values are stored every second, from some time in February until the beginning of October.
I would like to create a table say for Pitch 1, that would extract all the Pitch1 results per month, so I would have a table with newRecordTime, FebPitch1, MarPitch1, ...
Any assistance would be appreciated.
Regards
Andrew
David L Morris
Hj Andrew,  You might want to test something like this SQL and extend it to insert the results into your new table
select '07', sum(Pitch1) from YourTable where strftime('%m',RecordTime) = '07'
This should get total for July
Hope it helps
David
Fred Meier
If I understand your request, this could be a way to insert a record for a specific year(2009).
   Dim laPitch1s(1 to 12) as Double
   slSel "Select strftime('%m',RecordTime) as Month, Pitch1 from CurrentTable where strftime('%Y',RecordTime) = '2009'"
   do while slGerRow
      laPitch1s(val(slFN("Month")) = val(Picth1)
   slExe slBuildInsertOrUpdate("NewTable", datetime('now','localtime') & $NUL & _
                                           format$(laPitch1s(1)) & $NUL & _
                                           format$(laPitch1s(2)) & $NUL & _
                                           etc.......
I like to store date/time as FILETIME (quad) values in the DB.  This allows you to do date math and selections with your SQL statements directly from the DB.
