February 27, 2020, 04:20:57 am
SQLMan - Database Manager for SQLitening
Started by Rolf Brandt, December 06, 2009, 08:06:18 am
December 06, 2009, 08:06:18 am Last Edit: April 17, 2010, 10:35:35 am by Rolf Brandt
SQLiteningMan - a Database Manager for SQLitening
SQLiteningMan is written PB 9 / FireFly 3. The full source code is availabe on the Paul Squire's FireFly3 Forum. Please not that SQLiteningMan is at a very early stage of development. It certainly is not bug free.
SQLiteningMan can work in local or Client / Server mode.
So far I have implemented the following functions:
- Connect to a server
- Open a database
- Read and display a recordset in a listview
- Layout - Changing the fontsize of the listview
- Add records
- Edit records
- Delete records
- Show some database info (will be extended)
- A QuickSQL function
- A SQL Query Builder
- Grid sorting (Credit goes to Jean-Piere Leroy)
- Column Auto Sizing (Credit goes to Jean-Piere Leroy)
- Create databases
- Create tables
- Create indeces- Helpfile
- Create triggers
- Export to CSV
- Grid Printing - Column width reflected in printout
Something about the speed of SQLitening - I tested this app with the sample database that Fred Meier provided. These are the machines I used for testing:
- Server: AMD Athlon 5000 with 2.6 GHz, 2 GB RAM, Win7 Ultimate
- Dev machine: AMD Athlon 4850e with 2,526 MHz, 4 GB RAM, Win XP Pro SP3
- NetBook: Acer 751, Atom Z520, 1.30 GHz, 2 GB RAM, Win XP Home SP3
Speed on Desktop Machine, reading 10,000 records:
- LAN (cable):  0.937 sec
- Local:        0.704 sec
Speed on NetBook, reading 10,000 records:
- Local:        2.781 sec
- WLAN:         3.719 sec
- Internet:     7.516 sec  (Mobile connection via UMTS Stick)
A complete setup with all dependencies, helpfile, and sample database can be downloaded here:
http://sqlitening.rbsoft.eu/SQLiteningMan_Setup.exe
Last Update: 2009-12-25
www.rbsoft.eu
Update:
Fixed some bugs.
Changed Layout to tabbed dialogs.
Download and screenshots in first message of thread.
www.rbsoft.eu
Update v1.0.0.71
Corrected bug frmAddModify
Changed Layout to Tab based rather then Popup Dialogs
Added NOT LIKE to Query Builder
Added Database creation
Still fidgeting with implementation of ESCAPE in Query Builder
frmAddModify - set Cancel property  =True for Cancel button
Added DoubleClick event in Grid to open edit dialog
Corrected Click/DblClick behaviour in Treeview
QueryBuilder - Added UpDown  control to change order of selected fields
MainWindow - Added Indices to Treeview
Database Creation - Added Create Index
Database Info - Added Listview for TableDefinition
Database Info - Added Index information
Download in first message of thread.
www.rbsoft.eu
Minor Update!
v1.0.0.72
Bugfix in Add/Edit record.
www.rbsoft.eu
Bugfix!
v1.0.0.73
www.rbsoft.eu
Update!
v1.0.0.74
Changes:
Implemented Creation of Triggers
frmAddModify again - jumps to next field after edit (finally)
Changed name of executable to SQLiteningMan to reflect it's real purpose.
www.rbsoft.eu
Update!
v1.0.0.75
Changes:
RecordBrowser - right mouseclick opens Edit dialog with selected column
ToolsMenu - Export to CSV
Updated helpfile
Complete setup with all dependencies, helpfile, and sample database:
www.rbsoft.eu
Update!
v1.0.0 Release 86
Changes:
New Layout - Selected record displayed in 2nd Listview (see image)
New Feature - Grid printing, column width is reflected in printout.
www.rbsoft.eu
Fredrick Ughimi
Update!
v1.0.1 Release 148
Changes:
Supports password protected database files now.
Some quirks fixed.
Rolf
www.rbsoft.eu
Rudolf Fuerstauer
Hi Rolf,
thank you for the new version, but I can not connect to the database.
I get a connection to the server, but not to the database.
Rudolf
Thanks Rudolf,
I am gonna check it out. Found a little bug anyway.
Are you sure that there is no error in database name or password?
Rolf
www.rbsoft.eu
Rudolf Fuerstauer
Yes, the database name and the password is correct.
I've even tried using another database and see the same behavior.
Rudi
