Starting/Stopping SQLITENINGSERVER without compromising datases connected
Started by John Lever, January 20, 2010, 08:14:17 AM
John Lever
Dear All,
1. Is it possible to start/stop SQLITENINGSERVER from a PB9 application ?
2. Does the start/stop  close SQLITENINGSERVER immediately or wait until all transactions in progress are finished - I would imaginge the former as a SELECT with a  volume of data returned may take a long time.?
3. The question in 2. leads to question as to whether stopping SQLITENINGSERVER , power cut on just server PC or across all PCs etc could leave a database corrupted ?
Best Regards,
John Lever
Fred Meier
Quote1. Is it possible to start/stop SQLITENINGSERVER from a PB9 application?
Yes, but only if the PB app is running on the server.  Check out the StopService rut in SQLiteningServerAdmin for a sample.  If there was demand for this, I could add command line parms to SQLiteningServerAdmin so other programs could run it.
Quote2. Is the stop SQLITENINGSERVER immediate or waits until all transactions in progress are finished.
Immediate
Quote3. Stopping SQLITENINGSERVER , power cut on just server PC or across all PCs etc could leave a database corrupted ?
Yes, but would be corrected/rollbacked on the next start.
