May 25, 2020, 07:31:24 am
ASCII Control Characters
Started by Marty Francom, January 21, 2010, 07:46:11 am
Marty Francom
I have a need to embed  ACSII Control characters in certain fields in my Sqlite database.    Specifically thoughs characters are:
   Chr$(28)   (File Separator)
   Chr$(29)  (Group Separator)
   Chr$(30)   (Record Separator)
   Chr$(31)   (Unit Separator)
Are there any known problems in doing so?
Fred Meier
None.  If you wanted to insert Chr$(0) then you would have to use slExeBind.
Marty Francom
Quote from: Fred Meier on January 21, 2010, 11:24:09 am
Wonderful...
I have some fields that need to be parsed after they are retrieved from the database and I want to use a delimiter that was not typable from the key board so that it would be unlikely the user would be able to type a delimiter character into the field data which could cause problems when I parsed the field.
Thanks Fred you have been most helpful.
