October 18, 2021, 09:45:21 PM
SQLitening API's
Started by Fred Meier, July 29, 2010, 02:37:09 PM
Fred Meier
SQLitening comes with three different API's as follows:
   Basic     ---  Dll name is SQLitening.Dll
             ---  Include name is SQLitening.Inc
             ---  All routines begin with sl.
   Special   ---  Dll name is SQLiteningS.Dll
             ---  Include name is SQLiteningS.Inc
             ---  All routines begin with sls.
   Universal ---  Dll name is SQLiteningU.Dll
             ---  Include name is SQLiteningU.Inc
             ---  All routines begin with slu.
All DLL's are written in PowerBASIC and use the SDECL (aka STDCALL)
convention for parameter passing.  SDECL specifies that the declared
procedure uses the "Standard Calling Convention" as defined by Microsoft.
When calling an SDECL procedure, parameters are passed on the stack from
right to left and the stackl is automatically cleaned before execution
returns to the calling code.
PowerBASIC allocates strings using the Win32 OLE string engine.
This allows you to pass strings from your program to DLLs, or
API calls that support OLE strings.
   Which API or DLL should you use?
Basic:: Always try to use the Basic API.  If you language supports passing
OLE strings both ByVal and ByRef then you should be able to use the Basic
API.  OLE strings are allocated using the Win32 OLE string engine.  There
are some routines in the Basic API that will probably only work with
PowerBASIC.  slSelAry is one that passes an array and therefore may only
work in PowerBASIC.  You may need to modify the include file
(SQLitening.Inc) to support your language
Special:: If your language supports OLE string passing but only ByRef
(Visual Basic) then the Special API will probable work for you.  The
language must also support optional parameter passing.  The slSelAry is
not available in this API.  You will need to modify the include file
(SQLiteningS.Inc) to support your language This DLL is a front-end to the
Basic API.
Universal:: If your language does not support OLE strings then the Special
API will probable work for you.  This API will work for any language that
can call a standard Dll.  The parameter passing is patterned after the
Windows API.  The slSelAry is not available in this API.  You will need to
modify the include file (SQLiteningU.Inc) to support your language This
DLL is a front-end to the Basic API.  Documentation about parameter passing
is located in the include file.
