January 17, 2022, 10:44:19 PM
How to retrieve???
Started by Gary Stout, January 18, 2011, 06:07:50 PM
Gary Stout
I am finally getting the ball rolling with SQLitening after putting it off for way too long now.
I have a table that contains 5 fields :
FamilyID
MemberID
TransID
BatchID
EventID
This table basically stores program information for the next Transaction # ID, for example. There will never be more than 1 record in the table.
Since I don't know exactly what the TRANSID will be, how can I retrieve this field value without doing a search for unknown information?
In other words, if this was a random file, I would retrieve the record by record number, without searching, and use the value that the record held.
hopefuly this makes sense  ;)
Gary
Gary Stout
gary@sce4u.com
Marc Giao
January 18, 2011, 07:19:36 PM #1 Last Edit: January 18, 2011, 07:21:44 PM by Marc Giao
Hi Gary,
Assume the table is called "tbl_ids" and the fields contain strings, then it would be as follows:
slSel "SELECT * FROM tbl_ids"
slGetRow
a$ = slFN("FamilyID")
b$ = slFN("MemberID")
c$ = slFN("TransID")
d$ = slFN("BatchID")
e$ = slFN("EventID")
slCloseSet 'just in case you have more rows and don't know it :)
That's it, hope it helps.
Marc
Gary Stout
Marc,
Thanks for the reply!
In searching the forums, I did find something that seemed to work ok. I do understand your example as well.
slSEL "Select * FROM ProgramData WHERE RowID = 1", %rs1
Gary
Gary Stout
gary@sce4u.com
Marc Giao
Hi Gary,
Yes, that will do it too but I prefer not to reference rows so here is one more way if you just want one or more fields:
QuoteslSel "SELECT TransID FROM PorgramData"
Don't you just love how simple it is :)
Marc
Gary Stout
Quote from: Marc Giao on January 19, 2011, 12:42:00 AM
I do love the simplicity. I have been able to eliminate a bunch of Tsunami search code. With Sqlitening, it is amazing how few lines of code will do the same thing and more.  :)
Much more control over how the data is retrieved.
Gary Stout
gary@sce4u.com
