April 16, 2021, 06:41:52 PM
"Where" string in slBuildInsertUpdate
Started by Gary Stout, January 30, 2011, 12:49:35 AM
Gary Stout
Can someone give me an explanation of the "Where" string in the slBuildInsertUpdate command.  I understand that if it is omitted, then Insert is assumed. I guess I am confused on its meaning and how it relates to an Update.
Gary
Gary Stout
gary@sce4u.com
Frank W. Kelley
The "where" string in the slBuildInsertOrUpdate function specifies the condition for the update (i.e.: which record(s) should be updated).
For example, if the string "RowID = 22" is supplied as the "where" argument, the record with RowID 22 will be updated. In a broader sense, you can use "Age > 20" to apply the update to all records containing an Age value greater than 20.
This is similar to "UPDATE tablename SET Fulltime = TRUE WHERE Age > 20" only slBuildInsertOrUpdate assembles all the conditionals for you (and also handles embedded single quotes -- a lifesaver!)
Hope this helps.
Gary Stout
Frank,
Thanks for your reply. That makes a little more sense. Currently, I am using the following code that I was able to experiment with and seems to work, even though I really didn't understand why or how.
103203 is a field value but not a row id number. So, can row id be a value within a record or would this normally be a row number?
wStr = "rowid = '103203'"
Gary
Gary Stout
gary@sce4u.com
Hi Gary,
check in the FireFly Forum for "SQLitening for Beginners".
Iput a minimal SQLitening Database project to show how to create a database, a table, add, update, and delete records, and display records in a listview control. That might help a little.
www.rbsoft.eu
Frank W. Kelley
The "where" value can be anything that corresponds to a field name:
wstr = "Firstname = 'Bob' AND Age > 22"
wstr = "Year > 1999"
It does not necessarily have to be a Row ID, although (for me, at least), the Row ID is probably the most common "where" value that is used.
Gary Stout
Thanks guys! I think I now have a better understanding of how this works. From reading your description, I am still not quite sure why the code I am using works, but it seems to.  The number that I mentioned, (103203),  is not actually a row id number, but rather a member number within the record that is being edited.
Rolf, I have downloaded your example also to look over and try to get a better grasp.
Once I get past the learning curve, I will probably use Sqlitening for all my data needs. I have already been able to eliminate alot of code from a current project. Things that took many many lines of code to do in
Tsunami can be done in just a few lines of code in SL.
Thanks again,
Gary
Gary Stout
gary@sce4u.com
Gary, SQLite will at times report success even when nothing was updated.  For example:
- Delete non-existant row, SQLite returns %SQLite_OK
- Update non-existant row, SQLite returns %SQLite_OK
Use slGetChangeCount to verify that records were in fact updated.
RowID values are integer class and should not be quote enclosed in SQL statements.
Gary Stout
Bern,
Thanks for the info as well. I will check slGetChangeCount to verify. Basically, what I was doing..... I had SQLExpert open also and after I tried updating something, I would check SE to see if the changes were made. It appeared that the items were changed, but based on what I have learned in this thread, I don't see how they could have been.
Thanks again,
Gary
Gary Stout
gary@sce4u.com
