ZLib Wrapper Routines
Started by Rolf Brandt, February 23, 2011, 11:08:56 AM
Hello Fred,
I was just toying with those routines:
http://www.sqlitening.com/support/index.php?topic=3254.0
Can they be used to create zip files from existing files or directories also?
Is there an example?
www.rbsoft.eu
Fred Meier
Yes, these routines can read/write/create standard zip files.  I will work up some examples and post later.
www.rbsoft.eu
Fred Meier
I downloaded and reviewed Zipper.Zip and found that Zipper.Bas is a
program that if you compile and run it will create a standard .Zip file
called Test.Zip and then unzip from it.  Let me know if you need more
examples?
Hello Fred,
what I really need is to programmatically zip an existing file - let's say a .bas or .exe file - or even a complete directory with several files. I could not find out how to do that with the zipper bas ruts.
www.rbsoft.eu
Fred Meier
This snippet will zip the Ziipper.Bas file to Test.Zip.  Replace
PbMain in Ziipper.Bas with this snippet.
I just now noticed that there are two i's in "Zipper", my mistake.
   Local lsA as String
   Local lsZCB as String
   arZipFileInsertOpen "Test.Zip", lsZCB
   open "Ziipper.Bas" for binary lock shared as #1
   get$ #1, lof(#1), lsA
   close #1
   arZipFileInsertPut lsZCB, "Ziipper.Bas", lsA
   arZipFileInsertClose lsZCB
To do a folder, you would have to do someting like following:
   for each file in folder
      open file_name for binary lock shared as #1
      close #1
      arZipFileInsertPut lsZCB, file_name, lsA
   next
That is great, Fred. Thanks a lot!
www.rbsoft.eu
Fredrick Ughimi
Hello,
Is there a way one can unzip a zipped file using the technique Fred posted a while ago?
Best regards,
#8
Yes.  I'm not sure this is from his code.                       https://forum.powerbasic.com/forum/user-to-user-discussions/third-party-addons/29121-litezip-liteunzip/page2?t=28376&page=2
copy sqliteningzlib.dll to zlib.dll or change calls.
FUNCTION PBMAIN
   LOCAL lsA, lsB AS STRING
   LOCAL lsZCB AS STRING
   ' zip it
   arZipFileInsertOpen "Text.Zip", lsZCB
   lsA = "This is some data to put in zip file."
   arZipFileInsertPut lsZCB, "MyFile.Txt", lsA
   ' unzip it
   arZipFileGetFile "Text.Zip", 1, lsB
   ? lsB
Fredrick Ughimi
Hello CJ,
Cool. Really cool.
I would take a closer look later.
Thank you, CJ.
I know there are also some routines that call SqliteningZlib.dll the same way SQLitening does using AuxRuts if you need them.
Fredrick Ughimi
Hello CJ,
Where are these keywords from:
arZipFile...
Don't think they are in the SQLitening help file.
Regards,
They are from the routines in the download link to zipper.zip
Fredrick Ughimi
CJ,
I just tried downloading the zipper.zip and I got:
"404 - Attachment Not Found"
Fredrick Ughimi
I just downloaded the one you uploaded.
