July 13, 2020, 02:21:44 am
Thanks
Started by sclark, June 18, 2011, 07:36:32 pm
sclark
Fred,
Thanks for the tool! What a great tool, thank you for all your work!
i haven't ever used a database, but your docs & help file (Thanks to who ever did this!) & examples are getting me further along.
i am running your tool on VB 2010 Express. i have run into a few issues, but i am making progress. My PC is a Vista machine. i have gotten connected locally to a DB which i wanted to be able to extract info from. This DB is created by a store bought program for its use. So far i have gotten several of your functions to work, which allow me to open the db, get the column count, get the row count, & get the column names. Just thought i would let you know that it is working to some extent on my dev setup. i have run into limitation of VB 2010 express, string arrays returned are only seen as a single string. i figure this is due to VB having an object for strings and have not been able to crack a way to read past the first Null. Here is where i wish i had C tools and could setup a pointer to the string and evaluate past the first Null. But so far i have found ways to use other SQLitening  functions to achieve what i need.
Thank You again !!!
steve
Fred Meier
