Introduction (for use with VB6)
Started by dessql, July 22, 2012, 01:45:40 PM
dessql
I am looking for a sqlite client/server solution for VB6. I am testing SQLitening running in server mode, however there seems to be a problem when retrieving data from the slsF() or slsFN() functions.. The problem only happens in client remote / server mode.
Welcome!
We have some users here that use SQLitening in VB6. Post your code that is failing. Also, are you sure the connection to your server is actually happening and no error codes returned. Ensure your server configuration file is properly setup.
