January 17, 2022, 09:38:34 PM
Exporting SQLitening Table to MS Excel
Started by Fredrick Ughimi, August 09, 2012, 09:25:31 PM
Fim
 http://www.libxl.com/ look like the perfect solution.
As I understand, Libxl creates and writes Xlib an Excel file directly without going over Excel.
And then it will go fast, probably even faster than importing a CSV file.
Hopefully you can also control whether a field should be entered as text or number,
which you can not do with a CSV file.
I have been looking for a long time after this ..
Fim W
Fim
I have received the e-mail from subbport@libxl:
Hello Fim W
Fim W
Fredrick Ughimi
Hello Fin,
Sure sounds good. Thanks for sharing.
Best regards,
