Reg ODBC provider to open SQLLite
Started by balaji sukumar, September 18, 2012, 04:46:00 AM
balaji sukumar
Hi all,
I have a problem in connecting to SQLite Data file from SSIS package using ODBC provider. Please let me the driver that is required to connect to file(the file will not be on a physical path instead on a sharepoint doc library).
SQLitening does not use, and is not compatible with, an ODBC driver.
This is not an SQLite support forum. This is an SQLitening support forum. SQLitening is an addon to SQLite that allows SQLite to be used in a client/server setting.
