Saving Images Revisited - Best Practice
Started by Fredrick Ughimi, January 02, 2013, 10:44:26 PM
Fredrick Ughimi
Hello,
Is it best practice to save Images in a separate table? Because when I tried saving an image along with other items the image get saved but I null in other fields.
slExe "Begin Immediate"
            Errorcode& = slExe (slBuildInsertOrUpdate("tblBioData", "'" & sPHINo & "'" & $Nul & sTitle & $Nul & sSurname & $Nul & sOthernames _
            & $Nul & SQLiteDate(sDateCreated) & $Nul & sAddress & $Nul & sOccupation & $Nul & sSex & $Nul & sChronicConditions & $Nul & sAge _
            & $Nul & sAgeClass & $Nul & sMaritalStatus & $Nul & sSpouseName & $Nul & SQLiteDate(sBirthDate) & $Nul & sReligion _
            & $Nul & sPlan & $Nul & sClass  & $Nul & sFamilySize & $Nul & sGenotype & $Nul & sBloodGroup & $Nul & sKinName & $Nul & sPixName _
            & $Nul & sExpiryDate),"E")
           slGetFile sPixName, lsA
           slExeBind slBuildInsertOrUpdate("tblBioData","?", "Images"), slBuildBindDat(lsA)
        slExe "End"
Removed the delimiter and $CRLF from read dataset to verify file is 9216 bytes.
I have another question.
How do you insert a $NUL into F1 to automatically increment the rowid?
slExe("Create Table If not Exists T1(F1 INTEGER PRIMARY KEY ,F2,F3)")
#COMPILE EXE "\sql\bin\BlobTest"
#DIM ALL
#INCLUDE "\sql\inc\sqlitening.inc"
FUNCTION PBMAIN AS LONG
  LOCAL s, sBuffer, sAll AS STRING
  LOCAL x, columns AS LONG
  slGetFile("\windows\write.exe", sBuffer) '9216 bytes
  slOpen("test.db3","C")
  slExe("Drop Table If Exists T1")
  slExe("Create Table If not Exists T1(F1,F2,F3)")
  s = slBuildBindDat("column one") & _
      slBuildBindDat("column two") & _
      SlBuildBindDat(sBuffer)
  slExeBind "Insert into T1 values(?,?,?)", s
  slSel "Select f3 from T1"
  columns = slGetColumnCount
  IF columns = 0 THEN EXIT FUNCTION
  s = ""
  DO WHILE slGetRow
    FOR x = 1 TO Columns
      s = s + slf(x)
    sAll = sAll + s
  LOOP
  ? STR$(LEN(sAll))  '9216 bytes
Fred, if you were trying to UPDATE the record that was inserted after the BEGIN call, you need to add a record/index identifier  (rsWhere parameter) to the slBuildInsertOrUpdate function that is being passed to slExeBind.
Fred Meier
Bern's answerer is correct but I have a question --- why are you updating the row immediately after inserting, why not just insert all, including the image, using a single slExeBind?
QuoteIs it best practice to save Images in a separate table?
All depends on how often they are accessed. If not as often as the other fields then I would consider using another file and doing slAttach only when the image is needed.
QuoteHow do you insert a $NUL into F1 to automatically increment the rowid?
slExeBind slBuildInsertOrUpdate("T1", "NULL" & $Nul & "?" & $Nul & "?"), s
Fredrick Ughimi
Hello,
I have two questions. Been struggling with this for a while now.
1. How to insert the  "E" parameter of the slBuildInsertOrUpdate function for an INSERT operation to prevent duplicate entries because field HospitalNo is unique
slGetFile sPixPath, sPicture '9216 bytes
s = slBuildBindDat(sHospitalNo, "T") & _
      slBuildBindDat(sName, "T") & _
      slBuildBindDat(sPixPath, "T") & _
      SlBuildBindDat(sPicture)
slExeBind slBuildInsertOrUpdate("tblTestImages", "?" & $Nul & "?" & $Nul & "?" & $Nul & "?"), s
If Errorcode& = 19 Then
     MsgBox "HospitalNo Already Exist", %MB_TASKMODAL Or %MB_ICONINFORMATION, VD_App.Title
     Control Set Focus nCbHndl, %ID_FRMUPDATEDOCTORS_TXTNAME
     Exit Function
  ? "Saved!"
2. How to insert the  rsWhere parameter of the slBuildInsertOrUpdate function for an UPdate operation
  'slExeBind "Insert into tblTestImages values(?,?,?,?)", s
? "Updated!"
[code]
Fredrick Ughimi
For my new Update routine I get:
slExeBind slBuildInsertOrUpdate("tblTestImages", "?" & $Nul & "?" & $Nul & "?" & $Nul & "?", "rowid=" & sRecordNo), _
                                    slBuildBindDat(sPicture)
I get a syntax error.
It compiles with PB10
#COMPILE EXE "\sql\bin\test.exe"
#DIM ALL
FUNCTION PBMAIN () AS LONG
  LOCAL sPixPath AS STRING
  LOCAL sPicture AS STRING
  LOCAL sRecordNo AS STRING
  LOCAL sHospitalNo AS STRING
  LOCAL sName AS STRING
  slExeBind slBuildInsertOrUpdate("tblTestImages", "?" & $NUL & "?" & $NUL & "?" & $NUL & "?", "rowid=" & sRecordNo), _
Fredrick Ughimi
Yeah compiles here. But gives a run time syntax error 1 when trying to execute it.
#8
There is a comma where a  & should be in the second parameter string the rsValues (the , before "rowid=")
slBuildInsertOrUpdate (rsTable String, rsValues String, [rsColumns String, rsWhere String]) String
Should be
slExeBind slBuildInsertOrUpdate( _
   "tblTestImages","?" & $NUL & "?" & $NUL & "?" & $NUL & "?" & $NUL & sRecordNo), _
#DIM ALL
  LOCAL sPixPath,sPicture, sRecordNo, sHospitalNo, sName AS STRING
  slConnect "192.168.1.2",51234
  slOpen "test.db3","c"
  slExe "drop table if exists tblTestImages"
  slExe "create table if not exists tblTestImages(f1,f2,f3,f4,F5)"
  sPixPath = "sPixPath"
  'slGetFile sPixPath, sPicture '9216 bytes
  sPicture  = "sPicture"
  sHospitalNo = "sHospitalNo"
  sName       = "sName"
  sRecordNo = "sRecordNo"
Fredrick Ughimi
This is an UPDATE routine. slBuildInsertOrUpdate is seeing sRecordNo as the fifth value. It isn't. tblTestImages has just four fields. sRecordNo is supposed to be the ROWID.
#10
http://www.sqlitening.com/support/index.php?topic=3004.0
I am studying this thread from June 2009 on the subject.
Not finding an example using these three together.
slExeBind
slBuildBindData.
ExampleC.bas uses  this format:
slExeBind "Update Customers Set Memo = ? where CustomerID = " & READ$(llDo), slBuildBindDat(lsMemo, "TCN")
Not able to get UPDATE to work with the 3 functions together.
Fredrick Ughimi
This UPDATE routine worked perfectly. I clearly forgot to add the field names:
   "tblTestImages","?" & $Nul & "?" & $Nul & "?" & $Nul & "?", "HospitalNo, Name, PixPath, Picture", "rowid=" & sRecordNo), _
  ? "Updated!"
#12
Fredrick,
Thank you for posting the code!
I will work on a function to encapsulate slExeBind
because I do not like hardcoding data values.
1) Separated the SQL statement from the bind data
to come up with CALL slExeBind(sql$,sBindData$)
which makes it a bit easier to understand and
allows looking at the SQL part before calling.
2) Update failures ARE NOT REPORTED so added slGetChangeCount.
3) New function will automatically create the "?" and $NULs.
Others have probably already done this.
4) slExe "BEGIN" before first slGetChangeCount and slExe "END" after second slGetChangeCount?
#DIM ALL
  LOCAL sIpAddress    AS STRING
  LOCAL PortNumber    AS LONG
  LOCAL sDataBase     AS STRING
  LOCAL sTableName    AS STRING
  LOCAL sColumnNames  AS STRING
  LOCAL F1,F2,F3,F4   AS STRING
  LOCAL sWhere        AS STRING
  LOCAL sql           AS STRING
  LOCAL sBindData     AS STRING
  LOCAL sLayout       AS STRING
  LOCAL llChangeCount AS LONG
  sIpAddress = "192.168.1.2"
  PortNumber = 0                  'default port
  sDataBase  = "test.db3"         'database name
  sTableName = "tblTestImages"    'table  name
  slConnect sIpAddress,PortNumber 'connect if remote
  slOpen sDataBase, "C"           'open/create database
  REM slExe "drop table if exists " + sTableName 'drop previous table
  sColumnNames = "F1,F2,F3,F4"
  slExe "create table if not exists " + sTableName + " (" + sColumnNames +")"
  F2 = "Name"
  F3 = "cloud.jpg"
  slGetFile F3, F4
  sWhere = ""  'insert a record
  sWhere = "rowid < 11"  'update multiple records
  F1 = TIME$  'see if field 1 changed to the time"
  sLayout = "?" & $NUL & "?" & $NUL & "?" & $NUL & "?"
  llChangeCount = slGetChangeCount("T") 'total changes since open
  sql = slBuildInsertOrUpdate( _
   sTableName, _                                  'table name
   sLayOut, _                                     '? & NULS
   sColumnNames,                              _   'column names
   sWhere)                                        'where clause
  sBindData = slBuildBindDat(F1, "T") & _
   slBuildBindDat(F2, "T") & _
   slBuildBindDat(F3, "T") & _
   slBuildBindDat(F4, "B") 'blob/image
  slExeBind sql,sBindData
  'total changes now minus before calling slExeBind.
  llChangeCount = slGetChangeCount("T") - llChangeCount
  IF LEN(sWhere) THEN  'updating
    IF llChangeCount THEN
      ? "Update" + STR$(llChangeCount)
      ? "Update failed",%MB_ICONERROR,sWhere
  ELSE                  'inserting
      ? "Insert" + STR$(llChangeCount)
      ? "Insert failed",%MB_ICONERROR,sWhere
Fredrick Ughimi
Hello CJ,
Thanks for sharing your thoughts
Hello,
The next step is trap error 19 in the SAVE (INSERT) routine. I get syntax error with code below. I tried various option. No dice.
Errorcode& = slExeBind(slBuildInsertOrUpdate("tblTestImages", "?" & $Nul & "?" & $Nul & "?" & $Nul & "?"), "E"), _
          MsgBox "HospitalNo Already Exists ", %MB_TASKMODAL Or %MB_ICONINFORMATION, VD_App.Title
          Control Set Focus nCbHndl, %ID_FRMCHART_TXTHOSPITALNO
          Exit Function
? "Saved!"
There is another means to trap error 19 though. The code below works:
slSEL "SELECT HospitalNo From tblTestImages WHERE HospitalNo = '" + sHospitalNo + "' "
If IsTrue slGetRow Then
     MsgBox "HospitalNo Already Exist",%MB_TASKMODAL Or %MB_ICONINFORMATION, VD_App.Title
     Exit Function
But I'd like to see the first code option work.
#14
slGetInsertID () Quad
Returns the rowid key of the most recent insert into the database.
Returns zero if an error occurs and the global return errors flag is on.
