Saving Images Revisited - Best Practice
Started by Fredrick Ughimi, January 02, 2013, 10:44:26 PM
Inserts can be trapped like any other error because an error is returned.
If slSetProcessMods "E0" is used the slGetChangeCount will still return 0 if an insert error occurs.
It is just the update that doesn't return an error.
Fredrick Ughimi
Yeah I use the slGetChangeCount function in my SAVE and UPDATE routines. Something like:
If slGetChangeCount = 0 Then
        ? "Record Not Saved!", %MB_TASKMODAL Or %MB_ICONINFORMATION, VD_App.Title
        Exit Method
     Else
End IF
#17
I missed the question in reply #13 about the syntax error.
The "E" (handle our own errors rsModChar for any lurkers) needs to be at the end of the call.
This is one reason that I separated the slBuildInsertOrUpdate from the same call in the second code block below.
It is a bit hard for me to follow all the parameters.
    LOCAL ErrorCode AS LONG
    Errorcode& = slExeBind( _
    slBuildInsertOrUpdate("tblTestImages", "?" & $NUL & "?" & $NUL & "?" & $NUL & "?"), _
     slBuildBindDat(F1, "T") & _
     slBuildBindDat(F2, "T") & _
     slBuildBindDat(F3, "T") & _
     slBuildBindDat(F4, "B"),"E")
     IF Errorcode& THEN
          MSGBOX "Error"
        ? "Saved!"
or
sql = slBuildInsertOrUpdate( _
   sTableName, _              'table name
   sLayOut, _                 '? & NULS
   sColumnNames,          _   'column names
   sWhere)                    'where clause
sBindData = _ &
  result = slExeBind(sql,sBindData, "E")
  IF result THEN ? "Trapped error" + STR$(result)
Fredrick Ughimi
CJ,
Have you tested your codes above? None of the options traps the error 19.
Yes, they all work.
The result code 19 comes back using the "E" parameter.
#COMPILE EXE "\sql\bin\slexebind.exe"
#DIM ALL
#INCLUDE "\sql\inc\sqlitening.inc"
FUNCTION PBMAIN () AS LONG
  LOCAL sIpAddress    AS STRING
  LOCAL PortNumber    AS LONG
  LOCAL sDataBase     AS STRING
  LOCAL sTableName    AS STRING
  LOCAL sColumnNames  AS STRING
  LOCAL F1,F2,F3,F4   AS STRING
  LOCAL sWhere        AS STRING
  LOCAL sql           AS STRING
  LOCAL sBindData     AS STRING
  LOCAL sLayout       AS STRING
  LOCAL llChangeCount AS LONG
  'slSetProcessMods "E0"
  sIpAddress = "192.168.1.2"
  PortNumber = 0                  'default port
  sDataBase  = "test.db3"         'database name
  sTableName = "tblTestImages"    'table  name
  slConnect sIpAddress,PortNumber 'connect if remote
  slOpen sDataBase, "C"           'open/create database
  'slExe "drop table if exists " + sTableName 'drop previous table
  sColumnNames = "F1,F2,F3,F4"
  slExe "create table if not exists tblTestImages(F1 UNIQUE,F2,F3,F4)"
  F1 = "Number"
  F2 = "Name"
  F3 = "cloud.jpg"
  slGetFile F3, F4
  sWhere = ""  'insert a record
  'sWhere = "rowid < 11"  'update multiple records
  F1 = "SAME VALUE"  'see if field 1 changed to the time"
  sLayout = "?" & $NUL & "?" & $NUL & "?" & $NUL & "?"
  llChangeCount = slGetChangeCount("T")
   sWhere)
   #IF 0
     slBuildBindDat(F4, "B"),"E0")
     IF Errorcode& = 19 THEN
          MSGBOX "Error"
    ? "Saved!"
  #ENDIF
  sBindData = _ &
  LOCAL result AS LONG
  result = slExeBind(sql,sBindData, "E0")
  llChangeCount = slGetChangeCount("T") - llChangeCount
  IF LEN(sWhere) THEN  'updating
    IF llChangeCount THEN
      ? "Update" + STR$(llChangeCount)
      ? "Update failed",%MB_ICONERROR,sWhere
  ELSE                  'inserting
      ? "Insert" + STR$(llChangeCount)
      ? "Insert failed",%MB_ICONERROR,sWhere
Fredrick Ughimi
CJ,
Yeah they all work. Sorry my mistake. I removed the index earlier on when I was testing for other things.
I hear ya.
I added a UNIQUE  clause and often forget to delete previous test table.
Not sure about the error 19 being returned, but can live with that.
Fredrick Ughimi
CJ,
It returns error 19 alright:
Errorcode& = slExeBind(slBuildInsertOrUpdate("tblTestImages", "?" & $Nul & "?" & $Nul & "?" & $Nul & "?"), _
                                    slBuildBindDat(sHospitalNo, "T") & _
                                    slBuildBindDat(sName, "T") & _
                                    slBuildBindDat(sPixPath, "T") & _
                                    slBuildBindDat(sPicture, ("B")),"E")
If Errorcode& = 19 Then
      MsgBox "HospitalNo Already Exists o", %MB_TASKMODAL Or %MB_ICONINFORMATION, VD_App.Title
      Control Set Focus nCbHndl, %ID_FRMCHART_TXTHOSPITALNO
      Exit Function
Fredrick Ughimi
Hello,
slGetFile sPixName, sPicture, "E0" '9216 bytes
Errorcode& = slExeBind(slBuildInsertOrUpdate("tblBioData", "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & _
"?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & _
"?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?"), _
      slBuildBindDat(sTitle, "T") & _
      slBuildBindDat(sSurname, "T") & _
      slBuildBindDat(sOthernames, "T") & _
      slBuildBindDat(SQLiteDate(sDateCreated), "T") & _
      slBuildBindDat(sPhoneNo, "T") & _
      slBuildBindDat(sEmailAddress, "T") & _
      slBuildBindDat(sHomeAddress, "T") & _
      slBuildBindDat(sOfficeAddress, "T") & _
      slBuildBindDat(sCompany, "T") & _
      slBuildBindDat(sOccupation, "T") & _
      slBuildBindDat(sSex, "T") & _
      slBuildBindDat(sAge, "T") & _
      slBuildBindDat(sAgeClass, "T") & _
      slBuildBindDat(sMaritalStatus, "T") & _
      slBuildBindDat(SQLiteDate(sBirthDate), "T") & _
      slBuildBindDat(sReligion, "T") & _
      slBuildBindDat(sStateOrigin, "T") & _
      slBuildBindDat(sTribe, "T") & _
      slBuildBindDat(sEnroleeNo, "T") & _
      slBuildBindDat(sCategory, "T") & _
      slBuildBindDat(sPlan, "T") & _
      slBuildBindDat(sEntitlements, "T") & _
      slBuildBindDat(sEnroleeExpiry, "T") & _
      slBuildBindDat(sHMOName, "T") & _
      slBuildBindDat(sLGA, "T") & _
      slBuildBindDat(sBirthPlace, "T") & _
      slBuildBindDat(sNationality, "T") & _
      slBuildBindDat(sPixName, "T") & _
      slBuildBindDat(sKinPhone, "T") & _
      slBuildBindDat(sKinEmail, "T") & _
      slBuildBindDat(sKinAddress, "T" ) & _
      slBuildBindDat(sKinName, "T") & _
      slBuildBindDat(sRelationship, "T") & _
The code above works locally and not remotely and I don't know why. Locally the image savesin the Picture field and can be retrieved easily when needed. But remotely, the image wouldn't save. Has anyone experience this before?
No, haven't had a problem.
Place "Hello, world!" in BlobFile.txt" on server
#COMPILE EXE "\sql\bin\test"
$IpAddress = "192.168.1.2"
%PortNumber = 51234
  LOCAL sPixName, sPicture,sql AS STRING
  LOCAL x, columns AS LONG
  slConnect $IpAddress,%PortNumber
  slOpen "test.db3
  slexe "Drop Table if exists T1"
  slexe "Create Table if not exists T1(F1)"
  sPixName = "Blobfile.txt"
  slExeBind("Insert into T1 values(?)",slBuildBindDat(sPicture))
  sql = "Select * from T1"
  slSel(sql)
  columns = slGetColumnCount
  DO WHILE slGetRow
    FOR x = 1 TO columns
      ? slf(x),,"slf"
  LOOP
Fredrick Ughimi
cj,
Executed your program with a little modification. I also created the file ("Blobfile.txt") the project directory -
#COMPILE EXE "test"
#INCLUDE "sqlitening.inc"
$IpAddress = "Server"
%PortNumber = 51234
  slConnect $IpAddress, %PortNumber
  slOpen ("test.db3","C")
  slSel(sql)
  DO WHILE slGetRow
      ? slf(x),,"slf"
  LOOP
I got error -9 = File does not exist. statement=GetFile "Blobfile.txt"
I guess this line:
is the culprite.
Was the file missing on the server in your program?
In other words,  did checking for an error in slGetFile solve the problem?
Fredrick Ughimi
Hello cj,
You program runs now since I moved the missing file on the server computer.
No. I saved it on a client computer. Must it be saved on the Server Computer?
Yes I did check for error by using the "E" modifier no error came out. Just blank.
Fredrick Ughimi
Hello,
Just tested my program with the "E2" modifier and I got the FILE NOT FOUND ERROR -9
slGetFile sPixName, sPicture, "E2"
But the same command works locally.
