April 16, 2021, 08:29:03 AM
Retrieve A particular Item From A Field.
Started by Fredrick Ughimi, January 06, 2013, 06:16:25 PM
Fredrick Ughimi
Hello,
With SQLitening how can one retrieve a particular value from a field. Lets say you these values in Field Age:
20  30  45  34  52
How can one retrieve only the third item (value 45) ?
Your question is not clear.
Do you have a column named FieldAge with separate records containing the values 20, 30, 45, 34, 52 or do you have a single record containing a string "20 30 45 34 52"?
If the latter, you need to use some string functions like PARSE$().
If the former, please show the table name and column name(s) that you want to retrieve and search criteria and I can help you with the correct SELECT statement.
Fredrick Ughimi
I meant retrieving items by the item position in a field. For example Item 3 above is 45.
Fred Meier
This would get the third lowest age   Select Age from MyTable Order by Age Limit 1 Offset 2
This would do the same thing   Select Age from MyTable Order by Age Limit 2,1
From SQLite doc:
QuoteThe LIMIT clause is used to place an upper bound on the number of rows
returned by a SELECT statement.  Any scalar expression may be used in the
LIMIT clause, so long as it evaluates to an integer or a value that can be
losslessly converted to an integer.  If the expression evaluates to a NULL
value or any other value that cannot be losslessly converted to an
integer, an error is returned.  If the LIMIT expression evaluates to a
negative value, then there is no upper bound on the number of rows
returned.  Otherwise, the SELECT returns the first N rows of its result
set only, where N is the value that the LIMIT expression evaluates to.
Or, if the SELECT statement would return less than N rows without a LIMIT
clause, then the entire result set is returned.
The expression attached to the optional OFFSET clause that may follow a
LIMIT clause must also evaluate to an integer, or a value that can be
losslessly converted to an integer.  If an expression has an OFFSET
clause, then the first M rows are omitted from the result set returned by
the SELECT statement and the next N rows are returned, where M and N are
the values that the OFFSET and LIMIT clauses evaluate to, respectively.
Or, if the SELECT would return less than M+N rows if it did not have a
LIMIT clause, then the first M rows are skipped and the remaining rows (if
any) are returned.  If the OFFSET clause evaluates to a negative value,
the results are the same as if it had evaluated to zero.
Instead of a separate OFFSET clause, the LIMIT clause may specify two
scalar expressions separated by a comma.  In this case, the first
expression is used as the OFFSET expression and the second as the LIMIT
expression.  This is counter-intuitive, as when using the OFFSET clause
the second of the two expressions is the OFFSET and the first the LIMIT.
This is intentional - it maximizes compatibility with other SQL database
systems.
Fredrick Ughimi
Hello Fred, yeah forgot about these. Thanks alot.  It  seems Offset means the number of records to be skipped.
