February 17, 2020, 12:51:06 am
unable to connect to server
Started by Richard, March 20, 2013, 12:06:08 pm
Richard
Hello,
I am testing the wrapper for Purebasic, and it seems to work ok in local mode and for localhost.
When I start the server with
Quotesluconnect("192.168.1.103",0)
I get error -16 - can not connect.
The IP adress is correct (checked with ping an Mysql)
Quotesluconnect("127.0.0.1",0) works
sluconnect("localhost",0) works
sluconnect() works
Can this have something to do with the config file? What should be in it?
Richard
Richard
Sorry, problem solved. I did put the IP adress in the config file, but forgot to restart the server.
Richard
