Hi
Started by cg2013, July 08, 2013, 04:46:59 AM
cg2013
Looking to use SQLite for VBA application to run on Windows 7-64 accessing a SQLite db on the local Windows machine, as well as another SQLite db on a remote Linux Apache server. SQLitening looked like it might do it, but on closer examination I find that the Server components are in Power Basic, which means a server running either DOS or Windows. Appears to be close but no cigar unless someone has rewritten the server routines to run under Linux. Otherwise looks like a good system.
Welcome! You're right, the server would need to run Windows unless you could try running it under Wine (I don't think anyone here has tried that).
Seems the lates versions of Wine do now support Windows Services. Check here:
https://help.ubuntu.com/community/WineServer
In case you give it a try I would love to here your experience.
Rolf
www.rbsoft.eu
