May 07, 2021, 11:49:42 PM
Compress/encrypt made easier
Started by cj, July 29, 2013, 01:46:16 PM
July 29, 2013, 01:46:16 PM Last Edit: August 01, 2013, 10:00:20 AM by cj
Please post any comments/suggestions.
Eliminate calling slBuildInsertOrUpdate, slBuildBindDat and slExeBind.
Those functions are called automatically within InsertRecord and UpdateRecord.
Calling syntax:
InsertRecord sTableName$, sInsertData$(),sInsertMod$()
UpdateRecord sTableName$,sColumnsToUpdate$,sUpdateData$(),sUpdateMod$(), sWhere$
The data for each column goes into either sInsertData$() or sUpdateData$().
If performing an update:
Columns names are separated by commas in sColumnsToUpdate$.
Example: sColumnsToUpdate$ =  "F1,F2,F3,Client,Invoice"
2 arrays should be REDIMed before each call (this may be improved upon.)
NumberOfColumnsToUpdate = 2  'change this
REDIM sUpdateData(NumberOfColumnsToUpdate)AS STRING
REDIM sUpdateMod(NumberOfColumnsToUpdate) AS STRING
Flags are set for each column by the elements in the arrays sInsertMod$() and sUpdateMod$().
sUpdateMod$(1) =  "TCN"  column 1 is  text/compress/encrypt.
sUpdateMod$(2) = " "T"     column 2 is text.
To decrypt/uncompress recordsets use SQLitening routines slFX, slFNX or slSelAry.
SlSelAry requires all rows for all columns used the same compression/encryption.
FUNCTION InsertRecord(sTableName AS STRING, sInsertData() AS STRING,sInsertMod() AS STRING) AS LONG
  LOCAL COL, NumberOfColumns AS LONG
  LOCAL sPlaceHolders, sBindData AS STRING
  NumberOfColumns = UBOUND(sInsertData)
  DIM sArray(1 TO NumberOfColumns) AS STRING
  FOR COL = 1 TO NumberOfColumns
    sArray(COL) = slBuildBindDat(sInsertData(COL),sInsertMod(COL))
  sBindData = JOIN$(sArray(),"")
  sPlaceHolders=REPEAT$(NumberOfColumns-1,"?"&$NUL) + "?"
  slExeBind slBuildInsertOrUpdate(sTableName,sPlaceHolders),sBindData
FUNCTION UpdateRecord(sTableName       AS STRING, _
                      sColumnsToUpdate AS STRING, _
                      sUpdateData()    AS STRING,    _
                      sUpdateMod()     AS STRING, _
                      sWhere           AS STRING) AS LONG
  NumberOfColumns = UBOUND(sUpdateData)
    sArray(COL) = slBuildBindDat(sUpdateData(COL),sUpdateMod(COL))
  slExeBind(slBuildInsertOrUpdate(sTableName,sPlaceHolders,sColumnsToUpdate,sWhere),sBindData)
Here is a demo with help after the code on modchars, compression and encryption.
[code]
#DIM ALL
#INCLUDE "sqlitening.inc"  'binding.bas
%DropTable = 0
FUNCTION PBMAIN () AS LONG
  LOCAL sDatabaseName, sTableName,sData,sColumnsToUpdate,sResult,sWhere,sIp AS STRING
  LOCAL TotalColumns,NumberOfColumnsToUpdate,x,PortNumber AS LONG
  '-- Define encryption key  ------------------------------------
  LOCAL sEncryptionKey AS STRING * 16 '16,24, or 32
  sEncryptionKey = "VALID"
  slSetProcessMods "K" + sEncryptionKey 'do not combine Mods
  '-- Set Database name, table name, option IP address ----------
  sDatabaseName = "Test.db3"
  sTableName     = "T1"
  sIp            = "192.168.1.2"   'optional IP address or computer name
  sIp            = "174.74.114.227" 'optional IP address or computer name
  PortNumber     = 0       '0 = default (normally 51234)
  '-- Connect to server if sIP defined --------------------------
  IF LEN(sIp) THEN  slConnect sIp,PortNumber 'internet
  '--  Open database ---------------------------------------------
  slOpen sDatabaseName,"C"
top:
  '-- Drop previous table (optional) ----------------------------
  IF %DropTable THEN slExe "Drop Table if Exists " + sTableName
  '-- Create table if it does not exist -------------------------
  slExe "Create Table If Not Exists " + sTableName + "(F1,F2)"
  '-- Insert record ---------------------------------------------
  TotalColumns = 2
  REDIM sArray(1 TO TotalColumns) AS STRING
  REDIM sInsertMod(1 TO TotalColumns) AS STRING
  FOR x = 1 TO TotalColumns
    sArray(x) = "(New column "+FORMAT$(x) + ")"
    sInsertMod(x) = "TCN"  'Text,compress,encrypt
  InsertRecord sTableName, sArray(),sInsertMod()
  sResult = "After insert:" + $CR + SQL("Select * from " + sTableName)
  '-- Update all columns ----------------------------------------
  NumberOfColumnsToUpdate = 2 'REDIM update arrays
  REDIM sUpdateData(1 TO NumberOfColumnsToUpdate)    AS STRING
  REDIM sUpdateMod(1 TO NumberOfColumnsToUpdate) AS STRING
  sUpdateData(1) = "(1)"
  sUpdateData(2) = "(2)"
  sUpdateMod(1) = "TCN"
  sUpdateMod(2) = "TCN"
  sColumnsToUpdate = "F1,F2"
  sWhere = "*"
  UpdateRecord sTableName,sColumnsToUpdate,sUpdateData(),sUpdateMod(), sWhere
  sResult = sResult + $CR + "After two column update:" + $CR + SQL("Select * from " + sTableName)
  '-- Update only one column ------------------------------------
  NumberOfColumnsToUpdate = 1 'REDIM update arrays
  sUpdateData(1) = "(Column 2 only updated)"
  sColumnsToUpdate = "F2"
  sWhere = "*"
  sResult = sResult + $CR + "After one column update:" + $CR + SQL("Select * from " + sTableName)
  x = MSGBOX(sResult,%MB_YESNOCANCEL,"[Y]es=Rerun   [N]o=Exit   Cancel=Drop table/rerun")
  IF x = %IDYES THEN
     GOTO TOP  ' ALT/Y rerun ALT/N exit (if options go off the screen)
  ELSEIF x = %IDNO THEN
  ELSEIF x = %IDCANCEL THEN
    GOTO TOP
  IF LEN(sIp) THEN slDisconnect
FUNCTION SQL(SqlStatement AS STRING) AS STRING
LOCAL columns,x AS LONG, s AS STRING
slSel SqlStatement: columns = slGetColumnCount
DO WHILE slGetRow
  FOR x = 1 TO Columns
    s = s + slfx(x,"DU") + ","  'slfx decrypt/uncompress
  ASC(s,LEN(s)) = 13            '$CR after each row
LOOP
FUNCTION = s
'Calling syntax:
'InsertRecord sTableName$, sInsertData$(),sInsertMod$()
'UpdateRecord sTableName$,sColumnsToUpdate$,sUpdateData$(),sUpdateMod$(), sWhere$
'See remarks after code on compression and encryption.
'Flags are set for each column by the elements in the arrays sInsertMod() and sUpdateMod$().
'sUpdateMod(1) =  "TCN"  column 1 is  text/compress/encrypt.
'sUpdateMod(2) = " "T"     column 2 is text.
'To decrypt/uncompress data see SQLitening routines slFX and slFNX.
'FUNCTION InsertRecord/UpdateRecord call slBuildBindDat to produce the specially
'formatted string for each column of the record. Supply the letters in the element
'InsertMod() or UpdateMod() for each column in the record.
'Calling Insert/Record/UpdateRecord does the following automatically:
'Returns aBindDat entry specially formatted string required by slExeBind.
'Data contains the value you want converted into a BindDat. A BindDat(s) is required
'to be passed to slExeBind. The returned data may also be compressed and/or encrypted.
'If an error occurs then the return value will be an empty string.
'Use slGetError or slGetErrorNumber to determine the error.
'ModChars:
