July 06, 2020, 03:26:15 pm
SQLite Query Question
Started by Atomic_Sheep, August 05, 2013, 09:16:09 am
Atomic_Sheep
Hi Guys,
Trying to write a query whereby I get a row if one of the row's column values equals to a certain value e.g.
SELECT column1, column2 FROM tblTable WHERE column3=7
Doesn't seem to be working, any ideas?
August 05, 2013, 10:05:24 am #1 Last Edit: August 05, 2013, 11:52:50 am by cj
Would have to see the exact insert statement and search.
Probably inserted 7 as '7' or inserted 7 and searched for '7'.
#INCLUDE "\sql\inc\sqlitening.inc"
FUNCTION PBMAIN () AS LONG
  slOpen "test.db3","C"
  slexe "create table if not exists t1(column1,column2,column3)"
  slexe "insert into t1 values(1,2,7)"
  MSGBOX SQL("select column1,column2 from t1 where column3=7")
FUNCTION SQL(SqlStatement AS STRING) AS STRING
LOCAL columns,x AS LONG, s AS STRING
slSel SqlStatement: columns = slGetColumnCount
DO WHILE slGetRow
  FOR x = 1 TO Columns
    s = s + slf(x) + ","  'slfx decrypt/uncompress
  ASC(s,LEN(s)) = 13            '$CR after each row
LOOP
FUNCTION = s
August 05, 2013, 11:16:51 am #2 Last Edit: August 05, 2013, 11:53:30 am by cj
#DIM ALL
  LOCAL squery, sresult,stemp AS STRING
  DO
    stemp = INPUTBOX$("Number in column3","Title","7")
    IF stemp = "" THEN EXIT DO
    stemp = FORMAT$(VAL(stemp)) 'numbers without quotes
    squery = "select column1,column2 from t1 where column3=" & stemp
    query squery,sresult
    ? squery & $CR & sresult,,EXE.FULL$
  LOOP
SUB query(SqlStatement AS STRING, sresult AS STRING)
LOCAL columns, colnum AS LONG
slSel SqlStatement
RESET sResult
DO WHILE slGetRow
  FOR colnum = 1 TO columns
    sResult = sResult + slf(colnum) + ","
  ASC(sResult,LEN(sResult)) = 13
LOOP
