May 07, 2021, 09:55:22 PM
Windows 7
Started by D. Wilson, October 01, 2013, 10:08:18 PM
D. Wilson
Ok I have to break some habits. I have always created my own directory (not under Program Files) and placed my program/data files  in those directories. I have found this to be very reliable in the past and has worked excellent for my needs.
But with Windows 7 -- Windows will not allow you to save to those directories without  setting the program to Administor level. However when I set a program for Adminstrator access - I get the pop up asking if I would like to allow the program to make changes to the computer.
It also does not like the app.path statement to get the path of the software. I used to create a file there where I kept all my settings.
What is the best approach to saving data and allowing user permissions on Windows 7 ??
Also does this effect SQLitening running in the client/server mode ??
Any thoughts or  advice would be greatly appreciated.
As I understand it, if you install the SQLitening server in it's own folder off the root, like:
C:\SQLIteningServer\
Instead of in a folder inside the \Program Files\ folder, you won't have problems with Windows 7 security settings - ie. the server can store databases in sub-folders to the server application folder.
It probably would be a "best practices" improvement for SQLItening to be enhanced to include some calls/functions that allow SQLitening clients to direct the server to store databases in the Windows approved application data folders.  It should be too hard to implement either - just a function to poll the server app for the application's data folder.  Then it's on the SQLitening client to create the database in the correct folder (or sub-folder).
