January 19, 2020, 04:00:49 pm
removing -shm and -wal file
Started by arief, May 16, 2014, 01:31:28 am
arief
Hi,
I've been using Sqlite for more than a years, everything goes smoothly.
But now I'm facing a problem, while I'm opening the sqlite database, its creating new file named [database name +-shm and -wal file.
So, when I'm trying to made some modification to the database from portable app like sqlitestudio, its always fail, all changes is rolling back. Any help to remove/avoid this file.
If I'm using from the application that I have made its working proper. only with portable I had a problem.
Any helps.?
Regards,
Arief
Try http://sqlite.1065341.n5.nabble.com
This is the SQLite mailing list and is monitored by Dr. Hipp.
