January 17, 2022, 09:18:37 PM
RE: Using multiple databases with slPushDataBase
Started by cj, May 31, 2014, 02:08:06 PM
Shows how database handle can be saved so database is not reopened with a new handle using slOpen.
#DIM ALL    'Test slPushDataBase/slPopDataBase
#INCLUDE "sqlitening.inc"
#INCLUDE "win32api.inc"
%Databases=3
%NumberOfTests=3
FUNCTION PBMAIN () AS LONG
  DIM sArray() AS STRING, sDBHandle() AS STRING, s AS STRING
  DIM counter AS LONG, dbNumber AS LONG
  DIM sDBHandle(%DataBases)
  FOR counter = 1 TO %NumberOfTests
    FOR dbNumber = 1 TO %Databases
      IF counter = 1 THEN                   'first time
        slOpen "DB"+ FORMAT$(dbNumber),"C"  'open database
        slExe "Drop Table if exists t"      'drop table in each DB, optional
        slPushDataBase sDBHandle(dbNumber)  'push handle
        slPopDataBase  sDBHandle(dbNumber)  'set current db handle
        slPopDataBase  sDBHandle(dbNumber)  'set current db dhandle
      slExe "Create Table if not exists t(Column_One)"
      slexe "Insert into t values('Insert - Hello, world! from table t of database  DB" + FORMAT$(dbNumber) + "')"
  FOR dbNumber = 1 TO %DataBases
    slSelAry "Select * from t", sArray(), "Q9c"
    s = s +  JOIN$(sArray(),$CRLF) + STRING$(2,$CRLF)
  slClose  'close last DB used
  ? s,, "Done, closed current database" + STR$(%DataBases)
  IF %DataBases > 1 THEN  'prove DB1 open
    slPopDataBase sDbHandle(1)
    slExe "Insert into t values('Insert - Bye world! in DB1')"
    ? JOIN$(sArray(),$CRLF),, "Prove DB1 is still open"
    ? "No databases open",,"Bye"
Is it worth it to slPushPopDatabase?
This just uses slOpen and slClose
#DIM ALL    'Test just using slOpen and slClose
%Databases=3
%NumberOfTests=3
  LOCAL s AS STRING
  LOCAL counter AS LONG, dbNumber AS LONG
  FOR counter = 1 TO %DataBases:KILL "DB" + FORMAT$(counter):NEXT:ERRCLEAR
      slClose
  'display results
    slOpen "DB" + FORMAT$(dbNumber),"C"
    slClose
    slOpen "DB1","C"
    ? JOIN$(sArray(),$CRLF),, "Prove this works"
    slClose
