Accessing a point in DB
Started by kepler, July 19, 2014, 11:17:07 AM
kepler
Hi,
I've already put a VB6 program to read a SQLite file :) But I have to read ALL the records...
Is there a way of getting a specific registry imediatly? Say, record/entry number 77?
Kind regards,
Kepler
#1
drop table if exists mytable;
create table if not exists mytable(RecNum integer primary key autoincrement,comment);
insert into mytable values(null,'one');
insert into mytable values(null,'two');
insert into mytable values(77,'seventy-seven');
insert into mytable values(null,'seventy-eight');
select * from mytable;
select * from mytable where rowid  = 77;
select * from mytable where recnum = 77;
results:
1  one
2  two
77  seventy-seven
78  seventy-eight
77  seventy-seven
77  seventy-seven
#INCLUDE "sqlitening.inc"
FUNCTION PBMAIN () AS LONG
  LOCAL s AS STRING
  slOpen "sample.db3","C"
  s=  "drop table if exists mytable;"
  s+= "create table if not exists mytable(RecNum integer primary key autoincrement,comment);"
  s+= "insert into mytable values(null,'one');"
  s+= "insert into mytable values(null,'two');"
  s+= "insert into mytable values(77,'seventy-seven');"
  s+= "insert into mytable values(null,'seventy-eight');"
  slexe s
  s = GetSet("select recnum,comment from mytable where rowid  = 77;") + $CR
  s+= GetSet("select recnum,comment from mytable where recnum = 77;") + $CR
  MSGBOX s + GetSet("select * from mytable where recnum = 77;"),,"Results"
FUNCTION GetSet(SqlStatement AS STRING) AS STRING
  LOCAL s() AS STRING
  slSelAry(SqlStatement,s(),"Q9c")
  FUNCTION = JOIN$(s(),$CRLF)
Results:
77   seventy-seven
77   seventy-seven
77   seventy-seven
