April 16, 2021, 07:39:47 AM
Counting numer of lines from a DISTINCT-command
Started by Fim, August 13, 2014, 12:27:48 PM
Fim
I have a table with many word lists, e.g astronauts, rocks, bridges Sweden, bridges World.
I create the table witH this:
CREATE TABLE Listord(
    Sprak       Text        not null,     = Language
    Listnamn    Text        not null,     = List name
    Ord         Text        not null,     = Word
    Unique (Sprak, Listnamn, Ord));
With this SQL-Command
SELECT DISTINCT  Listnamn FROM Listord where sprak = 'SE';
I can se the namne av all word lists, but, and that is the question,
how to count the number of word lists in the table??
COUNT (SELECT DISTINCT  Listnamn FROM Listord where sprak = 'SE';)  No, No
SELECT COUNT (DISTINCT  Listnamn FROM Listord where sprak = 'SE';)  No, No
/Fim W
Fim W
Pat Dooley
I am not sure what yo need.
maybe?
select Listnamm, count(*) as CNT from Listord group by Listnamm;
Select count(DISTINCT Listnamn) FROM Listord where sprak = 'SE'
If the word index is unique then multiple lists cannot use the same word.
Creating an index of (listname,word) solves that problem.
If using DISTINCT the syntax is:  SELECT COUNT(DISTINCT col1), COUNT(DISTINCT col2)
To avoid conflicts when entering duplicates are not wanted  INSERT OR IGNORE is used.
Hope this helps
%Word_Allowed_In_Multiple_Lists = 1
%DropTable = 0
#INCLUDE "sqlitening.inc"
FUNCTION PBMAIN () AS LONG   'fin2.bas
  LOCAL sArray() AS STRING, sTitle AS STRING, sResult AS STRING
  IF %Word_Allowed_In_Multiple_Lists THEN
    sTitle = "Word allowed in multiple lists"
    sTitle = "Word not allowed in multiple lists"
  slopen  "sample.db3","C"
  IF %DropTable THEN slExe "drop table if exists t1"
    slexe   "create table if not exists t1(id integer primary key, listname not null,word not null)"
  ELSE  'make word unique
    slexe   "create table if not exists t1(id integer primary key, listname not null,word not null UNIQUE)"
slexe "Create unique index if not exists t1_index on t1(listname,word)"
  slexe   "insert or ignore into t1 values(null,'ListA','pear')"
  slexe   "insert or ignore into t1 values(null,'ListA','apple')"
  slexe   "insert or ignore into t1 values(null,'ListB','pear')"
  slexe   "insert or ignore into t1 values(null,'ListB','apple')"
  slSelAry "Select rowid as rows,count(DISTINCT listname) as lists, count(DISTINCT word) as words from t1",sArray(),"Q9"
  IF UBOUND(sArray) > -1 THEN
    sResult = JOIN$(sArray(),$CR)
  slSelAry "Select * from t1 order by listname",sArray(),"Q9"
    ? CHR$(sResult,$CR,$CR,JOIN$(sArray(),$CR)),,sTitle
Results:
Select rowid as rows,count(distinct listname) as lists, count(distinct word) as words from t1
rows  lists  words
4       2      2
id   listname   word
2   ListA         apple
1   ListA         pear
4   ListB         apple
3   ListB         pear
Fim
Hi,
Exactly what I was looking for. A big thanks.
I have to learn SQL better.
Fim W.
Fim W
I have these:
The SQL Guide to SQLIte by Rick F. van der Lans
The Definitive Guide to SQLite by Michael Owens (older first edition)
http://www.sqlite.org/books.html
Free ebook:
http://it-ebooks.info/book/147/
It you scan for distinct in this ebook it will describe the syntax and
mention that every row must be compared against every other row.
Use CTRL+F + F3 to find what you want quickly.
Please set the zoom, etc to fit your needs.
If you have multiple monitors it is fantastic.
Many documents on sqlite site:
Just one:
http://www.sqlite.org/lang_select.html  (many links on this page)
http://www.tutorialspoint.com/sqlite/index.htm
Of course just searching google with SQLITE + something may work.
I highly suggest writing a function executor with a couple of text boxes and an execute button.
SQL entered into one text box and the results appear in the other.
If you do this a single function can be created to execute all your SQL statements in all your programs.
SQLitening function executor with PBWIN 10 source code.
http://www.sqlitening.com/support/index.php?topic=9299.msg24468;topicseen#msg24468
Comments on the function executor are welcome.
It will execute unlimited lines as long as each line (even comment lines) are ended with a semicolon.
Might want case insensitive list names and words by using collate nocase in the index statement.
This would prevent 'LISTA', 'ListA'  and multiple words like 'APPLE' and 'Apple".
%DropTable = 1
  ELSE  'make word unique to all tables
    slexe   "create table if not exists t1(id integer primary key, listname not null,word not null UNIQUE collate nocase)"
  slexe   "Create unique index if not exists t1_index on t1(listname collate nocase,word collate nocase)"
  slexe   "insert or ignore into t1 values(null,'ListB','APPLE')"
  slexe   "insert or ignore into t1 values(null,'Listb','APPLE')"
  slSelAry "Select rowid as rows,count(distinct listname) as lists, count(distinct word) as words from t1",sArray(),"Q9"
  slSelAry "Select * from t1 order by listname,word",sArray(),"Q9"
