January 17, 2022, 10:10:18 PM
Creating recordsets with or without binding
Started by cj, May 01, 2015, 02:18:46 PM
Each of these 4 examples produce the same result.
Example 1.  Create recordset to string looping through each row and column.
Example 2.  Create recordset to array
Example 3. Create recordset to string using compression and encryption.
Example 4. Create recordset to array using compression and encryption.
#INCLUDE "sqlitening.inc"
FUNCTION PBMAIN () AS LONG
  LOCAL sData AS STRING, sArray() AS STRING
  LOCAL COL,rows AS LONG
  'slConnect "",0  'ip address and port for client/server
  slOpen "sample.db3","C"  'create if it does not exist
  slexe "drop table if exists simple"
  slexe "create table if not exists simple(c1,c2)"
  slexe "insert into simple values('hello','world!')"
'Example 1.  Build recordset to string
  slsel "select * from simple"
  rows = 0
  sData = ""
  DO WHILE slgetRow
    INCR rows
    FOR COL = 1 TO slGetColumnCount
      sData +=  slf(COL) + ","
    ASC(sData,LEN(sData)) = 13 'last , to carriage return
  LOOP
  MSGBOX sData,,"Rows" + STR$(rows)
'Example 2.  Build recordset to array
  slSelAry("select * from simple",sArray(),"Q44 c")
  MSGBOX (JOIN$(sArray(),$CR)),,"Rows" + STR$(UBOUND(sArray))
'BOUND DATA EXAMPLES
'Insert text Compressed and Encrypted  TCN parameters
  slexe "delete from simple"   'delete previous data in table
  slSetProcessMods "K" + STRING$(16,"A") 'encryption key 16,24 or 32 bytes
  slExeBind "insert into simple values(?,?)", _
    slBuildBindDat("hello","TCN") + _
    slBuildBindDat("world!","TCN")
'Example 3.  Build recordset to string Decrypted and Uncompressed
  rows = 0
  sData = ""
  DO WHILE slgetRow
    INCR rows
      sData +=  slfx(COL,"DU") + ","  'decrypt uncompress
  LOOP
'Example 4.  Build recordset array Decrypted and Uncompressed
  slSelAry("select * from simple",sArray(),"D1,2 U1,2 Q44 c")
'Notes:
'D1,2  = Decrypt columns 1,2
'U1,2  = Uncompress columns 1 and 2
'Q44   = delimit columns with a comma ASCII 44
'c     = do not include column headings in recordset
The examples above returned records without a WHERE clause.
If there is a WHERE clause with BINDING:
    sBind = slBuildBindDat(sInput,"TCN")
    slExeBind "insert into simple values(?)",sBind
    slSelBind "Select c1 from simple where c1 =?",sBind
    'slSel "select c1 from simple"  'if no WHERE
    IF slGetErrorNumber = 0 THEN
      DO WHILE slGetRow
        ? slfx(1,"DU"),,"slSelBind Results" 'D=decrypt, U=uncompress
      LOOP
  LOOP
