April 01, 2020, 02:26:43 pm
order by wrong (with compression)
Started by cj, May 25, 2015, 06:28:21 am
May 25, 2015, 06:28:21 am Last Edit: May 26, 2015, 02:49:16 am by cj
I  see some SQL statements will not work correctly  because they are working on compressed or encrypted data.
ORDER BY is one of them.
#INCLUDE "sqlitening.inc"
FUNCTION PBMAIN () AS LONG
  slOpen "sample.db3","C"
  slexe "create table if not exists t1(c1)"
  slexebind "insert into t1 values(?)",slBuildBindDat("A","TC")
  slexebind "insert into t1 values(?)",slBuildBindDat("B","TC")
  slexebind "insert into t1 values(?)",slBuildBindDat("C","TC")
  slsel "select c1 from t1 order by c1"
  DO WHILE slGetRow
    s$ = s$ + slfx(1,"U")
  LOOP
  ? s$,,"Should be ABC"  'returns BAC
Here is a probably bad solution re-writing the uncompressed/encrypted data into another table.
  LOCAL s() AS STRING, sql,sResult AS STRING, x AS LONG
  sql = "select c1 from t1 order by c1"
  slSetProcessMods "K" + SPACE$(32) 'encrypt key
  DIM s(3) AS STRING
  s(1) = slBuildBindDat("A","TCN")
  s(2) = slBuildBindDat("B","TCN")
  s(3) = slBuildBindDat("C","TCN")
  slexebind "insert into t1 values(?)",JOIN$(s(),""),"V1"
  slSelAry sql,s(),"(Qc)(D1)(U1)"
  'Remove "CN" binding
  FOR x=1 TO UBOUND(s):s(x) =slBuildBindDat(s(x),""):NEXT
  slopen ":memory:"
  slexe "create table t1(c1)"
  slSelAry sql,s(),"Qc"
  ? JOIN$(s(),""),,sql  'returns ABC
