August 26, 2019, 03:19:35 am
LIKE requires TEXT to use index
Started by cj, May 31, 2015, 10:56:35 am
Test indexes using SQLite explain statement
https://www.sqlite.org/eqp.html
To use indexes with LIKE it is important to Create table table1(column1 TEXT COLLATE NOCASE);
SQLitening example showing EXPLAIN QUERY PLAN:
#INCLUDE "sqlitening.inc"
FUNCTION PBMAIN () AS LONG 'like.bas
  LOCAL s() AS STRING, s AS STRING
  slOpen "sample.db3","C"
  slexe "drop table if exists t"
  slexe "create table t(c1 text)"
  slexe "create index i on t(c1)"
  slSelAry "explain query plan select * from t where c1 like 'Z%'",s(),"Q9c"
  ? JOIN$(s(),$CRLF),,"Index not used"
  'SCAN TABLE T
slexe "create table  t(c1 text collate nocase)"
  ? JOIN$(s(),$CRLF),,"Index used"
  'SEARCH TABLE t USING COVERING INDEX i (c1>? AND c1<?)
