May 07, 2021, 09:49:37 PM
add column with varname 'as'
Started by WiglWagl, June 28, 2015, 04:05:06 PM
WiglWagl
Hi,
is there any known problem with the varname "as". I try to add a column named "as". Ok that works fine, but
i ca't insert any item on this table, because there is a problem with the column 'as':  :P
Any idesas?
Thanks
regards
Rene
June 29, 2015, 11:15:15 AM #1 Last Edit: June 29, 2015, 11:26:46 AM by cj
https://www.sqlite.org/lang_keywords.html
It is a reserved word so create fails in this example.
#INCLUDE "sqlitening.inc"
FUNCTION PBMAIN () AS LONG
  LOCAL s() AS STRING
  slopen "sample.db3","C"
  slexe "create table if not exists t1(as)"
  slexe "insert into t1 values('a')"
  slselAry "select * from t1",s(),"Q9"
  ? JOIN$(s(),$CR)
The docs show some ways to modify the 'keyword', but I wouldn't do it.
  LOCAL s() AS STRING
  slexe "create table if not exists t1([as])"
  slselAry "select [as] from t1",s(),"Q9"
  ? JOIN$(s(),$CR)
