July 05, 2020, 07:30:45 am
FileWatcher
Started by cj, July 02, 2015, 08:53:22 am
July 02, 2015, 08:53:22 am Last Edit: July 02, 2015, 09:15:17 am by cj
Monitor SQLiteningServer.log or even an entire database for any change.
Only text files may be viewed.
May be useful to alert you when people are logging in or using a database.
Thanks to Larry Charlton at the PowerBASIC site for the code.
http://www.powerbasic.com/support/pbforums/showthread.php?t=50986
FileWatcher.Bas
#COMPILE EXE
#DIM ALL
'http://www.powerbasic.com/support/pbforums/showthread.php?t=50986
'Larry Charlton modified  7/2/2015 with 3 modifications for SQLitening
'Added 3 modifications:
'filename to watch, beep on change, optionally show log
$FileNameToWatch="c:\sql\bin\sqliteningserver.log" 'modification 1 remark to ask for name
%BeepOnAnyChange = 1  'modification 2  change to 0 for no beep on changes
%ShowLogOnChanges =1  'modification 3
%UNICODE = 1
#INCLUDE ONCE "win32api.inc"
#INCLUDE ONCE "FileWatcher.inc"
GLOBAL fw AS iFileWatcher  ' File watcher
GLOBAL filename AS WSTRING ' File we're watching
GLOBAL hDlg AS DWORD:       ' Open dialog
%FILE_EXIT    = 1005
%FILE_OPEN    = 1006
%CTL_TEXT     = 1001
FUNCTION PBMAIN()
  LOCAL hFont, hTopMenu, hFileMenu, hAccel, hRes AS DWORD
  DIM menuAccel(0) AS ACCELAPI
  DIALOG NEW PIXELS, %HWND_DESKTOP, "File Watcher", 105, 114, 607, 483, %WS_OVERLAPPEDWINDOW, TO hDlg
  CONTROL ADD TEXTBOX, hDlg, %CTL_TEXT, "", 0, 0, 0, 0, %WS_CHILD OR _
                                                            %WS_VISIBLE OR _
                                                            %WS_BORDER OR _
                                                            %WS_TABSTOP OR _
                                                            %WS_VSCROLL OR _
                                                            %WS_HSCROLL OR _
                                                            %ES_LEFT OR _
                                                            %ES_MULTILINE OR _
                                                            %ES_READONLY OR _
                                                            %ES_AUTOHSCROLL OR _
                                                            %ES_AUTOVSCROLL,_
                                                            %WS_EX_RIGHTSCROLLBAR
  FONT NEW "Courier New", 10, 0, %ANSI_CHARSET TO hFont
  CONTROL SET FONT hDlg, %CTL_TEXT, hFont
  MENU NEW BAR TO hTopMenu
  MENU NEW POPUP TO hFileMenu
  MENU ADD POPUP, hTopMenu, "File", hFileMenu, %MF_ENABLED
  MENU ADD STRING, hFileMenu, "&Open" & $TAB & "Ctrl+O", %FILE_OPEN, %MF_ENABLED
  MENU ADD STRING, hFileMenu, "-", 0, 0
  MENU ADD STRING, hFileMenu, "E&xit", %FILE_EXIT, %MF_ENABLED
  MENU ATTACH hTopMenu, hDlg
  menuAccel(0).fVirt = %FVIRTKEY OR %FCONTROL OR %FNOINVERT
  menuAccel(0).Key = ASC("O")
  menuAccel(0).Cmd = %FILE_OPEN
  ACCEL ATTACH hDlg, menuAccel() TO hAccel
  DIALOG SHOW MODELESS hDlg, CALL ShowFileWatcherProc TO hRes
  GetNewFile()
  IF ISNOTHING( fw ) THEN EXIT FUNCTION
  CALL OnFileChanged( filename ): ' Initial load
  DO
    DIALOG DOEVENTS
  LOOP WHILE ISWIN(hDlg)
  IF ISOBJECT( fw ) THEN fw.Stop()
  FONT END hFont
CALLBACK FUNCTION ShowFileWatcherProc()
  LOCAL w, h AS LONG
  SELECT CASE CONST CB.MSG
    CASE %WM_SIZE
      DIALOG GET CLIENT hDlg TO w, h
      CONTROL SET SIZE hDlg, %CTL_TEXT, w, h
    CASE %WM_COMMAND
      SELECT CASE CONST CB.CTL
        CASE %FILE_OPEN: CALL GetNewFile():   CALL OnFileChanged( filename )
        CASE %FILE_EXIT: DIALOG END hDlg
SUB GetNewFile()
  'do not display file to watch if $FileNametoWatch is used
  LOCAL newFile AS WSTRING
  #IF %DEF($FilenameToWatch)
    newfile = $FilenameToWatch
  #ELSE
  DISPLAY OPENFILE 0, , , "Select File To Watch", "\sql\bin", "logs"+$NUL+"*.log"+$NUL,"sqliteningserver.log", "", %OFN_FILEMUSTEXIST TO newFile
  IF newFile = "" THEN EXIT SUB
  #ENDIF
  fw = NOTHING
  filename = newFile
  CALL StartFileWatcher( fw, newFile, CODEPTR( OnFileChanged ) )
SUB OnFileChanged( filename AS WSTRING )
  LOCAL value, c AS STRING
  LOCAL i, f AS LONG
  STATIC cnt AS LONG
  IF %BeepOnAnyChange THEN BEEP
  IF %ShowLogOnChanges = 0 THEN GOTO OnlyShowCount
  ' Reload file
  ERRCLEAR
  f = FREEFILE
  FOR i=1 TO 10
    OPEN filename FOR BINARY ACCESS READ LOCK SHARED AS #f
    IF ERR=0 THEN EXIT FOR
    ERRCLEAR
    SLEEP 100
  IF ERR<>0 THEN
    CLOSE #f
    CONTROL SET TEXT hDlg, %CTL_TEXT, "(unable to open file " + ERROR$ + ")"
    GET$ #f, LOF(#f), value
    CLOSE #f
OnlyshowCount:
    INCR cnt
    c = FORMAT$( cnt, "#,##0" )
    value = BUILD$("Load round ", c, $CRLF, value )
    CONTROL SET TEXT hDlg, %CTL_TEXT, value
FileWatcher.Inc
%BUFSIZE = 1024
SUB NewFileWatcher( obj AS iFileWatcher, filename AS WSTRING, BYVAL notifyRoutine AS DWORD )
  obj = CLASS "cFileWatcher"
  obj.Initialize( filename, notifyRoutine )
SUB StartFilewatcher( obj AS iFileWatcher, filename AS WSTRING, BYVAL notifyRoutine AS DWORD )
  CALL NewFileWatcher( obj, filename, notifyRoutine )
  obj.Launch( BYVAL 0 )
SUB NotifyPattern( filename AS WSTRING )
CLASS cFileWatcher
  INSTANCE ThreadParam AS LONG
  INSTANCE running_ AS LONG
  INSTANCE notifier_ AS iFileWatchNotifier
  INSTANCE notifyRoutine_ AS DWORD
  INSTANCE filename_ AS WSTRING
  INSTANCE hStop AS DWORD
  THREAD METHOD MAIN() AS LONG
  #ALIGN 4
    LOCAL buffer1 AS STRINGZ * %BUFSIZE
    LOCAL buffer2 AS STRINGZ * %BUFSIZE
    LOCAL hover AS OVERLAPPED
    LOCAL hWait() AS DWORD
    LOCAL dwWaitStatus, flags, hDir AS DWORD
    LOCAL fullPath, modFile AS WSTRING
    LOCAL finished, numBytes, cnt, i AS LONG
    LOCAL fn AS WSTRING PTR
    LOCAL fi AS FILE_NOTIFY_INFORMATION
    REDIM hWait(1) AS LOCAL DWORD
    IF ISFALSE ISFILE( filename_ ) OR notifyRoutine_=0 THEN EXIT METHOD
    CALL StartFileWatchNotifier( notifier_, filename_, notifyRoutine_ )
    fullPath = PATHSCAN$( PATH, filename_ )
    ' Other things we can watch for
    '%FILE_NOTIFY_CHANGE_FILE_NAME
    '%FILE_NOTIFY_CHANGE_DIR_NAME
    '%FILE_NOTIFY_CHANGE_ATTRIBUTES
    '%FILE_NOTIFY_CHANGE_SIZE
    '%FILE_NOTIFY_CHANGE_SECURITY
    flags = %FILE_NOTIFY_CHANGE_LAST_WRITE: ' Watching for file changes/writes
    hDir = CreateFile( BYVAL STRPTR(fullPath), %FILE_LIST_DIRECTORY, %FILE_SHARE_READ OR %FILE_SHARE_WRITE OR %FILE_SHARE_DELETE, BYVAL %NULL, %OPEN_EXISTING, %FILE_FLAG_BACKUP_SEMANTICS OR %FILE_FLAG_OVERLAPPED , %NULL)
    hWait(0) = CreateEvent( BYVAL %NULL, 0, 0, BYVAL %NULL )
    hWait(1) = CreateEvent( BYVAL %NULL, 0, 0, BYVAL %NULL )
    hStop = hWait(1)
    hover.hEvent = hWait(0)
    DO WHILE -1
      MEMORY FILL VARPTR( buffer1 ), %BUFSIZE, BYTE 0
      ResetEvent( hover.hEvent )
      'do not use VARPTR with Jose Roca includes
      IF ReadDirectoryChangesW(hDir, VARPTR(buffer1), %BUFSIZE, %FALSE, flags, %NULL, hover, %NULL) THEN
      'IF ReadDirectoryChangesW(hDir, buffer1, %BUFSIZE, %FALSE, flags, %NULL, hover, %NULL) THEN
        dwWaitStatus = WaitForMultipleObjects( 2, hWait(0), %FALSE, %INFINITE )
        SELECT CASE CONST dwWaitStatus - %WAIT_OBJECT_0
          CASE 0: ' Directory change signaled
            'If returnedBytes>0 Then
              MEMORY COPY VARPTR( buffer1 ), VARPTR( buffer2 ), %BUFSIZE
              notifier_.Changed( VARPTR( buffer2 ) )
            'End If
          CASE 1: ' hStop signaled
            EXIT LOOP
    LOOP
    hStop = 0
    CloseHandle( hWait(0) )
    CloseHandle( hWait(1) )
    CloseHandle( hDir )
    notifier_.Stop()
    notifier_ = NOTHING
  END METHOD
  INTERFACE iFileWatcher
    INHERIT IPOWERTHREAD
    METHOD Initialize( filename AS WSTRING, notifyRoutine AS DWORD )
      IF filename="" OR notifyRoutine=0 THEN EXIT METHOD
      IF filename_ = "" OR notifyRoutine_ = 0 THEN
        filename_ = filename
        notifyRoutine_ = notifyRoutine
    END METHOD
    PROPERTY GET Running() AS LONG
      PROPERTY = running_
    END PROPERTY
    PROPERTY GET Filename() AS WSTRING
      PROPERTY = filename_
    END PROPERTY
    PROPERTY GET NotifyRoutine() AS DWORD
      PROPERTY = notifyRoutine_
    END PROPERTY
    METHOD STOP()
      LOCAL fw AS iFileWatcher
      fw = ME
      SetEvent( hStop )
      fw.Join( fw, 0 )
      fw = NOTHING
    END METHOD
  END INTERFACE
END CLASS
SUB StartFileWatchNotifier( obj AS iFileWatchNotifier, filename AS WSTRING, BYVAL notifyRoutine AS DWORD )
  obj = CLASS "cFileWatchNotifier"
CLASS cFileWatchNotifier
  INSTANCE changed_ AS DWORD
  INSTANCE stopped_ AS DWORD
  INSTANCE fni AS FILE_NOTIFY_INFORMATION PTR
    LOCAL cnt AS LONG
    LOCAL fi AS FILE_NOTIFY_INFORMATION PTR
    LOCAL filename, fullPath, modFile AS WSTRING
    LOCAL i, finished AS LONG
    LOCAL ofs AS LONG
    LOCAL dwWaitStatus AS DWORD
    changed_ = hWait(0)
    stopped_ = hWait(1)
    filename = LCASE$( PATHSCAN$( NAMEX, filename_ ) )
    DO WHILE -1
      ResetEvent( changed_ )
        CASE 0: ' Changed
          fi = fni
          finished = 0
          WHILE NOT finished
            finished = ( @fi.NextEntryOffset = 0 )
            IF @fi.Action = %FILE_ACTION_MODIFIED AND @fi.FileNameLength THEN
              modFile = PEEK$$( VARPTR( @fi.FileName ), @fi.FileNameLength )
              i = LEN(modFile)
              WHILE i>1 AND ASC(modFile,i)<=32
                DECR i
              WEND
              modFile=LEFT$(modFile,i)
              modFile = LCASE$( DIR$( fullPath + modFile ) )
              IF modFile = LCASE$( filename ) THEN
                CALL DWORD notifyRoutine_ USING NotifyPattern( filename_ )
            fi += @fi.NextEntryOffset
          WEND
        CASE 1: ' Stopped
          EXIT LOOP
    LOOP
  END METHOD
  INTERFACE iFileWatchNotifier
      IF filename_<>"" OR notifyRoutine_ THEN EXIT METHOD
    END METHOD
    METHOD STOP()
      LOCAL fwn AS iFileWatchNotifier
      SetEvent( stopped_ )
      fwn = ME
      fwn.Join( fwn, 0 )
      fwn = NOTHING
    END METHOD
    METHOD Changed( BYVAL fi AS DWORD )
      fni = fi
      SetEvent( changed_ )
    END METHOD
  END INTERFACE
END CLASS
