May 07, 2021, 11:40:41 PM
A Three Table Query
Started by Fredrick Ughimi, August 01, 2015, 11:53:55 AM
Fredrick Ughimi
Hello,
Adapting Mike report solution at http://www.powerbasic.com/support/pbforums/showthread.php?p=480712#post480712 I have discovered that some existing records would display and others won't display. Don't know why that is. For instance this won't display even though the record exists.
Something not right I guess.
#COMPILE EXE
#DIM ALL
#INCLUDE "win32api.inc
#INCLUDE "sqlitening.inc"
#INCLUDE "ddoc_p32.inc"
'DDOC
'  Needed Color Constants (Vb compatible)
%vbBlack = &H0&
%vbRed = &HFF&
%vbGreen = &HFF00&
%vbYellow = &HFFFF&
%vbBlue = &HFF0000
%vbMagenta = &HFF00FF
%vbCyan = &HFFFF00
%vbWhite = &HFFFFFF
%vbGrey = &HC0C0C0
%LIGHT_SHADE = &HE0E0E0
%vbOrange = &HFF3118
FUNCTION PBMAIN () AS LONG
  slOpen ("GuestsProDB.db3","C")
  'Registration
   slExe BUILD$("Create Table If Not Exists tblRegistration(LoyaltyID TEXT COLLATE NOCASE, DateTaken TEXT, Title TEXT, Surname TEXT COLLATE NOCASE, Othernames TEXT COLLATE NOCASE, Sex TEXT,", _
  "MStatus TEXT, Nationality TEXT, CompanyAddress TEXT, PhoneNo TEXT, NoOfNights TEXT, NoOfAdults TEXT, DepartTo TEXT, MeansOfTravel TEXT,", _
  "NatureOfVisit TEXT, Account TEXT, RoomRate REAL, BillNo TEXT, ArrivalDate TEXT, DepartureDate TEXT, NoOfChildren TEXT, Occupation TEXT,", _
  "HomeAddress TEXT, ArriveFrom TEXT, VehicleNo TEXT, VehicleType TEXT, VehicleColour TEXT, PassportNo TEXT, AllienCertificateNo TEXT,", _
  "AccountSettledBy TEXT, RoomType TEXT, RoomNo TEXT COLLATE NOCASE, NoOfGuests TEXT, Time TEXT, Remarks TEXT, CheckedOut, StayOver,", _
  "ReceiptNo TEXT, Deposit REAL, VAT REAL, ServiceCharge REAL, Discount REAL, PaymentMode TEXT, ChequeNo TEXT, Cashier TEXT, LoyaltyGuestStatus TEXT)")
   slExe "Create UNIQUE Index If Not Exists Registrationndx1 ON tblRegistration(BillNo, LoyaltyID)"
   slExe "Create Index If Not Exists Registrationndx3 ON tblRegistration(Surname, Othernames)"
   'Sales
   slExe BUILD$("Create Table If Not Exists tblSales(Name Text, BillNo, DocketNo Text, RoomNo Text, Date Text, ProductNo Text Collate NOCASE, Description Text,", _
     "Category Text, Department Text, Quantity Integer, SellingPrice REAL, Discount, VAT REAL, ServiceCharge REAL, Remarks Text, Username Text)")
   slExe "Create Index If Not Exists Salesndx1 ON tblSales(DocketNo, ProductNo, Department)"
   'LaundryReceives
   slExe BUILD$("Create Table If Not Exists tblLaundryReceives(Date TEXT, BillNo TEXT, DocketNo TEXT, Name TEXT, Service TEXT, Quantity INTEGER, Price REAL, Discount REAL)")
   slExe "Create Index If Not Exists LaundryReceivesndx1 On tblLaundryReceives(Name, BillNo, DocketNo)"
  'ReportGuestsAccountStatus()
FUNCTION NigeriaDate(sDate AS STRING) AS STRING
     'From yyyy-MM-dd To dd-MM-yyyy
      FUNCTION = MID$(sDate,9,2) & "-" & MID$(sDate,6,2) & "-" & MID$(sDate,1,4)
FUNCTION SQLiteDate(sDate AS STRING) AS STRING
     'From dd-MM-yyyy To yyyy-MM-dd
      FUNCTION = MID$(sDate,7,4) & "-" & MID$(sDate,4,2) & "-" & MID$(sDate,1,2)
FUNCTION PBDate(sDate AS STRING) AS STRING
     '02-05-2010
   FUNCTION = MID$(sDate,4,2) & "-" & MID$(sDate,1,2) & "-" & MID$(sDate,7,4)
FUNCTION ReportGuestsAccountStatus() AS LONG
      LOCAL dbHandle&, LineSpacing!,iHandle%,Row!,TopMargin!,PageSize!,PageNumber&
      LOCAL detailline AS ASCIIZ * 200
      LOCAL detailline2 AS ASCIIZ * 200
      LOCAL SNo AS LONG
      LOCAL lTotalRecords&
      LOCAL sFrom AS STRING
      LOCAL sTo AS STRING
      LOCAL dTotalVATAmount AS DOUBLE
      LOCAL dGrossTotal AS DOUBLE
      LOCAL dVAT AS DOUBLE
      LOCAL dGross AS DOUBLE
      LOCAL dTotalServiceAmount AS DOUBLE
      LOCAL dTotalBill AS DOUBLE
      LOCAL dTotalDeposit AS DOUBLE
      LOCAL sBillNo AS STRING
      LOCAL dBalance AS DOUBLE
      LOCAL dTotalAmount AS DOUBLE
      LOCAL dTotalDiscount AS DOUBLE
      LOCAL dAccommodation AS DOUBLE
      LOCAL sSurname AS STRING
      LOCAL sOthernames AS STRING
      LOCAL dNETTOTAL AS DOUBLE
      LOCAL dSERVICECHARGE AS DOUBLE
      LOCAL dTotalDockets AS DOUBLE
      LOCAL dAccommodationLessDiscount AS DOUBLE
      LOCAL dDiscount AS DOUBLE
      LOCAL dTotalAdditionalPayments AS DOUBLE
      LOCAL dTotalPayments AS DOUBLE
      LOCAL Discount AS DOUBLE
      LOCAL dSalesAmount AS DOUBLE
      LOCAL dLaundryReceivesAmount AS DOUBLE
      LOCAL lTotalRooms&
      LOCAL Str AS STRING
      LOCAL sLoyaltyID AS STRING
      LOCAL sRoomNo AS STRING
      LOCAL dTotalSalesDockets AS DOUBLE
      LOCAL dTotalLaundryReceivesDockets AS DOUBLE
      LOCAL hjpg AS LONG
       LineSpacing = .2
      TopMargin   = .5
      PAGESIZE    = 7
       'note: If ddoc.exe does not exist endless loop here
      ihandle% = dpStartDoc(0,"Mega-Net GuestsPro - Guests Account Status Report","",%DDOC_INCH, %DDOC_PAPER_A4, %DDOC_PORTRAIT, %DDOC_SYSTEM_DEFAULT, %DDOC_BIN_AUTO OR %DDOC_ALLOWSMTP OR %DDOC_ALLOWSAVE OR %DDOC_ZOOMFIT)
       IF ihandle < 1 THEN
           MSGBOX "Could not StartDoc. Error number" + STR$(Ihandle)
           GOTO EndProgram
       dpSetTabs iHandle, "L.5W1 L1W1 L2W1 L3.2W2 L4.1W3 L7W1"
       ROW = PAGESIZE    '7 above                        'force new heading
      sFrom = "28-01-2015"
      sTo = "01-08-2015"
      sBillNo = "BN20828120152"
          'ReportsInformation.Reports
          slSEL "SELECT COUNT(*) As RowCount FROM tblSales WHERE Date BETWEEN '" + SQLiteDate(sFrom) + "' AND '" + SQLiteDate(sTo) + "' AND BillNo = '" + sBillNo + "' "
         IF ISTRUE slGetRow() THEN
            lTotalRecords& = VAL(slFN("RowCount"))
         slCloseSet
         slSEL "SELECT COUNT(*) As RowCount FROM tblRegistrationHistory WHERE DateTaken BETWEEN '" + SQLiteDate(sFrom) + "' AND '" + SQLiteDate(sTo) + "' AND BillNo = '" + sBillNo + "' "
            lTotalRooms& = VAL(slFN("RowCount"))
         slCloseSet
          slSel "SELECT SUM(SellingPrice * Quantity) As TotalSalesDockets, * From tblSales WHERE Date BETWEEN '" + SQLiteDate(sFrom) + "' AND '" + SQLiteDate(sTo) + "' AND BillNo = '" + sBillNo + "' "
            dTotalSalesDockets = VAL(slFN("TotalSalesDockets"))
          slCloseSet()
          slSel "SELECT SUM(Price * Quantity) As TotalLaundryReceivesDockets, * From tblLaundryReceives WHERE Date BETWEEN '" + SQLiteDate(sFrom) + "' AND '" + SQLiteDate(sTo) + "' AND BillNo = '" + sBillNo + "' "
            dTotalLaundryReceivesDockets = VAL(slFN("TotalLaundryReceivesDockets"))
          slCloseSet()
          dTotalDockets = dTotalSalesDockets + dTotalLaundryReceivesDockets
          slSel "SELECT SUM(Amount) As TotalAdditionalPayments, * From tblAdditionalPayments WHERE Date BETWEEN '" + SQLiteDate(sFrom) + "' AND '" + SQLiteDate(sTo) + "' AND BillNo = '" + sBillNo + "' "
            dTotalAdditionalPayments = VAL(slFN("TotalAdditionalPayments"))
          slCloseSet()
           slSEL "SELECT SUM(Deposit) as TotalDeposit, * FROM tblRegistrationHistory WHERE DateTaken BETWEEN '" + SQLiteDate(sFrom) + "' AND '" + SQLiteDate(sTo) + "' AND BillNo = '" + sBillNo + "' "
             dTotalDeposit = VAL(slFN("TotalDeposit"))
          slCloseSet()
          slSEL "SELECT SUM(Discount) as TotalDiscount, * FROM tblRegistrationHistory WHERE DateTaken BETWEEN '" + SQLiteDate(sFrom) + "' AND '" + SQLiteDate(sTo) + "' AND BillNo = '" + sBillNo + "' "
             dTotalDiscount = VAL(slFN("TotalDiscount"))
          slCloseSet()
          slSEL "SELECT SUM(NoOfNights * RoomRate) as Accommodation, * FROM tblRegistrationHistory WHERE DateTaken BETWEEN '" + SQLiteDate(sFrom) + "' AND '" + SQLiteDate(sTo) + "' AND BillNo = '" + sBillNo + "' "
             dAccommodation = VAL(slFN("Accommodation"))
             dVAT = VAL(slFN("VAT"))
             dServiceCharge = VAL(slFN("ServiceCharge"))
          slCloseSet
           dAccommodationLessDiscount =  dAccommodation -  dTotalDiscount
           dNETTOTAL = dAccommodationLessDiscount + dVAT + dSERVICECHARGE
            slSel "SELECT tblRegistrationHistory.DateTaken as RegistrationDateTaken," & _
            " tblRegistrationHistory.BillNo as RegistrationHistoryBillNo," & _
            " tblRegistrationHistory.Surname as RegistrationHistorySurname," & _
            " tblRegistrationHistory.Othernames as RegistrationHistoryOthernames," & _
            " tblRegistrationHistory.LoyaltyID as RegistrationHistoryLoyaltyID," & _
            " tblRegistrationHistory.RoomNo as RegistrationHistoryRoomNo," & _
            " tblSales.Date as SalesDate," & _
            " tblSales.BillNo as SalesBillNo," & _
            " tblSales.DocketNo as SalesDocketNo," & _
            " tblSales.RoomNo as SalesRoomNo," & _
            " tblSales.Description as SalesDescription," & _
            " tblSales.SellingPrice as SalesSellingPrice," & _
            " tblSales.Quantity as SalesQuantity," & _
            " tblSales.Name as SalesName" & _
            " FROM" & _
            " tblRegistrationHistory" & _
            " INNER JOIN tblSales ON (RegistrationHistoryBillNo=SalesBillNo)" & _
            " WHERE tblRegistrationHistory.DateTaken BETWEEN '" + SQLiteDate(sFrom) + "' AND '" + SQLiteDate(sTo) + "' AND tblRegistrationHistory.BillNo = '" + sBillNo + "'"
             DO WHILE slGetRow()
              GOSUB CheckPageSize
               dSalesAmount = VAL(slFN("SalesSellingPrice")) * VAL(slFN("SalesQuantity"))
              INCR SNo
               DetailLine$ =  _
                STR$(SNo) + $TAB + _
                NigeriaDate(slFN("SalesDate")) + $TAB + _
                slFN("SalesDocketNo") + $TAB + _
                slFN("SalesRoomNo") + $TAB + _
                slFN("SalesDescription") + $TAB + _
                FORMAT$(dSalesAmount)
                dpTabText iHandle%, ROW + 3.2, DetailLine
                ROW = ROW + LineSpacing                    'increment line counter
           LOOP
         '? "LaundryReceives starts with" + str$(sNo)
            " tblLaundryReceives.Date as LaundryReceivesDate," & _
            " tblLaundryReceives.BillNo as LaundryReceivesBillNo," & _
            " tblLaundryReceives.DocketNo as LaundryReceivesDocketNo," & _
            " tblLaundryReceives.Service as LaundryReceivesService," & _
            " tblLaundryReceives.Price as LaundryReceivesPrice," & _
            " tblLaundryReceives.Quantity as LaundryReceivesQuantity" & _
            " FROM" & _
            " INNER JOIN tblLaundryReceives On (RegistrationHistoryBillNo=LaundryReceivesBillNo)" & _
          DO WHILE slGetRow()
             GOSUB CheckPageSize
             'LaundryReceives
            dLaundryReceivesAmount = VAL(slFN("LaundryReceivesSellingPrice")) * VAL(slFN("LaundryReceivesQuantity"))
            INCR SNo
             DetailLine$ =  _
              NigeriaDate(slFN("LaundryReceivesDate")) + $TAB + _
              slFN("LaundryReceivesDocketNo") + $TAB + _
              slFN("LaundryReceivesDescription") + $TAB + _
              FORMAT$(dLaundryReceivesAmount)
          LOOP
          dpEndDoc iHandle%, %DDOC_END_VIEW + %DDOC_END_PRINT
        EndProgram:
CheckPageSize:
  IF ROW => PAGESIZE THEN
                IF PageNumber THEN      'If first page don't need a new page
                  dpNewPage iHandle%,  %ddoc_PAPER_A4, %DDOC_PORTRAIT, %DDOC_BIN_AUTO
               INCR PageNumber
                  hjpg = dpAddGraphic(ihandle%, EXE.PATH$ & "Logo.jpg")
                 IF hjpg THEN
                    dpDrawGraphic ihandle%, hjpg,3.8,.2,2,1
                dpText iHandle%, .5,TopMargin,  %DDOC_Left,"Page: "+ STR$(PageNumber)+""
               dpText iHandle%, 6,TopMargin,  %DDOC_Left,"Date: "+ PBDate(DATE$)+""
               dpText iHandle%, 6,TopMargin +.2,  %DDOC_Left,"Time: "+ TIME$+""
               ROW =TopMargin + LineSpacing * 4
               dpFont ihandle%, %DDOC_FONTNORMAL + %DDOC_FONTBOLD, 13, %vbGreen, "Arial"
               dpText ihandle, 4.25, 1.1, %DDOC_CENTER, "" & "gName"
               dpFont ihandle%, %DDOC_FONTNORMAL + %DDOC_FONTBOLD, 12, %vbBlack, "Arial"
               dpText IHandle%, 4.25, 1.4, %DDOC_CENTER, "" & "gAddress"
               dpFont ihandle%, %DDOC_FONTNORMAL + %DDOC_FONTUNDERLINE + %DDOC_FONTBOLD, 12, %vbBlack, "Arial"
               dpRect IHandle%, .4, 1.7, 8.0, 2.6, 3, %LIGHT_SHADE, 0
               dpText IHandle%, 4.25, 1.7, %DDOC_CENTER, "Guests Account Status Report"
               dpFont ihandle%, %DDOC_FONTNORMAL, 12, %vbBlack, "Arial"
               dpText IHandle%, 0.5, 2.0, %DDOC_LEFT, "Date: " &  sFrom  & " To  " & sTo
               dpText IHandle%, 3.7, 2.0, %DDOC_LEFT, "No Of Rooms: " + FORMAT$(lTotalRooms)
               dpText IHandle%, 6.2, 2.0, %DDOC_LEFT, "LoyaltyID: " & slFN("RegistrationHistoryLoyaltyID")
               dpText IHandle%, 6.2, 2.3, %DDOC_LEFT, "Room No: " & slFN("RegistrationHistoryRoomNo")
               dpText IHandle%, 0.5, 2.3, %DDOC_LEFT, "Check-In Bill No: " + slFN("RegistrationHistoryBillNo")
               dpText IHandle%, 3.7, 2.3, %DDOC_LEFT, "Name: " & slFN("RegistrationHistorySurname") & " " & slFN("RegistrationHistoryOthernames")
               dpText IHandle%, .5, 2.9, %DDOC_LEFT, "Deposit Paid: "
               dpText IHandle%, 3.0, 2.9, %DDOC_RIGHT,  FORMAT$(dTotalDeposit, "#,.00")
               dpText IHandle%, .5, 3.2, %DDOC_LEFT, "Additional Payments: "
               dpText IHandle%, 3.0, 3.2, %DDOC_RIGHT,  FORMAT$(dTotalAdditionalPayments, "#,.00")
               dTotalPayments = dTotalDeposit + dTotalAdditionalPayments
               dpText IHandle%, .5, 3.5, %DDOC_LEFT, "Total Payments: "
               dpText IHandle%, 3.0, 3.5, %DDOC_RIGHT,  FORMAT$(dTotalPayments, "#,.00")
               dpLine IHandle%, .5, 3.7, 3, 3.7, 0, %vbBlue
               dpText IHandle%, 4.0, 2.9, %DDOC_LEFT, "Accommodation: "
               dpText IHandle%, 7.0, 2.9, %DDOC_RIGHT,  FORMAT$(dAccommodation, "#,.00")
               dpText IHandle%, 4.0, 3.1, %DDOC_LEFT, "Discount: "
               dpText IHandle%, 7.0, 3.1, %DDOC_RIGHT,  FORMAT$(dTotalDiscount, "#,.00")
               dpText IHandle%, 4.0, 3.3, %DDOC_LEFT, "VAT: "
               dpText IHandle%, 7.0, 3.3, %DDOC_RIGHT,  FORMAT$(dVAT, "#,.00")
               dpText IHandle%, 4.0, 3.5, %DDOC_LEFT, "Service Charge: "
               dpText IHandle%, 7.0, 3.5, %DDOC_RIGHT,  FORMAT$(dServiceCharge, "#,.00")
               dpText IHandle%, 4.0, 3.7, %DDOC_LEFT, "Accommodation Net:"
               dpText IHandle%, 7.0, 3.7, %DDOC_RIGHT,  FORMAT$(dNETTOTAL, "#,.00")
               dpText IHandle%, 4.0, 3.9, %DDOC_LEFT, "Dockets(Total):"
               dpText IHandle%, 7.0, 3.9, %DDOC_RIGHT,  FORMAT$(dTotalDockets, "#,.00")
               dTotalAmount = dNETTOTAL +  dTotalDockets
               dBalance =  dTotalAmount - dTotalPayments
               dpText IHandle%, 4.0, 4.1, %DDOC_LEFT, "Total Amount Payable:"
               dpText IHandle%, 7.0, 4.1, %DDOC_RIGHT,  FORMAT$(dTotalAmount, "#,.00")
               dpText IHandle%, 4.0, 4.3, %DDOC_LEFT, "Balance:"
               dpText IHandle%, 7.0, 4.3, %DDOC_RIGHT,  FORMAT$(dBalance, "#,.00")
               dpLine IHandle%, 4.0, 4.5, 7, 4.5, 0, %vbBlue
               dpText IHandle%, .5, 10.7, %DDOC_LEFT, "___________________________"
               dpText IHandle%, 1.1, 10.9, %DDOC_LEFT, "Guest's Sign: "
               dpText IHandle%, 5, 10.7, %DDOC_LEFT, "___________________________"
               dpText IHandle%, 5.6, 10.9, %DDOC_LEFT, "Manager's Sign: "
               dpFont ihandle%, %DDOC_FONTNORMAL + %DDOC_FONTUNDERLINE + %DDOC_FONTBOLD, 9, %vbBlack, "Arial"
               dpTabText iHandle%, ROW + 3.4, "S/No" + $TAB + "Date" + $TAB + "DocketNo" + $TAB + "RoomNo" _
               + $TAB + "Description" + $TAB + "Amount"
               dpFont ihandle%, %DDOC_FONTNORMAL, 8, %vbBlack, "San Serif"
               ROW =  ROW + LineSpacing * 2.1
RETURN
