November 21, 2019, 03:01:34 am
Search Encrypted Dictionary Example
Started by cj, September 27, 2015, 12:46:21 pm
September 27, 2015, 12:46:21 pm Last Edit: October 05, 2015, 09:21:39 pm by cj
slConvertDat shouldn't be used with encrypted or compressed data.
It worked because the data wasn't being converted.    A new demo will be posted.
In function SearchWord, the slSelBing call requests two values, but you are only using one.  The SQL statement can be modified to only request the record number:
slSelbind "select rec_num from Wordtable where word=? limit 1",sBind
