September 18, 2020, 04:12:47 am
.mdf & .ldf files in SQLite for Mac
Started by ringleader, October 13, 2015, 04:05:29 am
ringleader
Hello all
A total SQL virgin here so please excuse any daft questions.
I have a SCADA system at work which backs trend data to a server which stores them as .mdf & .ldf files, I can easily use the WinCC application to render the data and then also export as a .csv file.  I want to take the raw data (.mdf &.ldf) files and use SQL to render the data and navigate. Is this possible?, I've tried a few things but just get "file is encrypted or not a database".  I don't believe the files are encrypted.
If it is possible please describe the steps.  I'm using a Mac.
Thanks in advance
Nick
