January 17, 2022, 10:20:57 PM
Torture test slDisconnect
Started by cj, October 22, 2015, 02:23:44 AM
October 22, 2015, 02:23:44 AM Last Edit: November 15, 2015, 05:33:36 AM by cj
slDisconnect/slConnect fixed in SQLiteningClient
What results did you see from your tests?  Here's an old post from Fred discussing results from his stress testing (albiet in local mode):
Quote from: Fred MeierI developed the stress test and ran it many times.  ...
I ran the test many times with different numbers of Bots.  I even ran it
several times with 500 Bots.  That means there were 500 processes(clients)
with 500 concerrent connections to SQLiteServer.  Each Bot would Insert,
Update, Delete and Select records to/from a single database.
The good news is --- SQLiteServer/SQLite produced valid results on EVERY
test, not a single failure.
http://www.sqlitening.com/support/index.php?topic=3279.msg16707#msg16707
