January 17, 2022, 10:21:31 PM
Assure threads allocate example
Started by cj, July 16, 2016, 02:30:44 PM
July 16, 2016, 02:30:44 PM Last Edit: July 20, 2016, 03:39:15 AM by cj
GLOBAL gsResult AS STRING
TYPE MyType
  sDatabase AS STRING * 64
  sIpAddress AS STRING * 32
  PortNumber AS LONG
  sql      AS STRING * 512
  hEventReady AS LONG
END TYPE
#INCLUDE ONCE "win32api.inc"
#INCLUDE ONCE "sqlitening.inc"
FUNCTION PBMAIN () AS LONG
  slSetProcessMods "E0" 'applies to all threads
  LOCAL x, Threads AS LONG, t AS MyType
  Threads = 5
  REDIM hThreads(1 TO Threads) AS LONG
  FOR x = 1 TO Threads
    t.sDatabase       = "sample.db3"
    t.sIpAddress      = "192.168.1.2" 'change this
    t.PortNumber      = 51234         'change this
    t.sql             = "select count(*) from parts"
    t.hEventReady     = CreateEvent (BYVAL 0, BYVAL %TRUE, BYVAL %FALSE, BYVAL 0)
    THREAD CREATE Test(VARPTR(t)) TO hThreads(x)
    WaitForSingleObject t.hEventReady,%INFINITE
    CloseHandle t.hEventReady
  waitformultipleobjects Threads, hThreads(1),%True,%INFINITE
  FOR x = 1 TO Threads 'close all thread handles
    THREAD CLOSE hThreads(x) TO hThreads(x)
  ? gsResult,%MB_SYSTEMMODAL,"Recordsets"
THREAD FUNCTION Test(BYVAL t  AS MyType PTR) AS LONG
  ThreadSafeHelper t
SUB ThreadSafeHelper(BYVAL t AS MyType PTR) THREADSAFE
  DIM s() AS STRING
  LOCAL sDatabase,sIpAddress, sql AS STRING, PortNumber AS LONG
  'Assign local variables to pointed to memory addresses
  sDatabase  = TRIM$(@t.sDatabase)
  sIpAddress = TRIM$(@t.sIpAddress)
  PortNumber = @t.PortNumber
  sql = @t.sql
  'Now allocated, let same memory address be reused
  SetEvent @t.hEventReady'thread allocate, release event
  slConnect sIpAddress,PortNumber
  IF slGetErrorNumber = 0 THEN
    slOpen sDatabase, "C"
    IF slGetErrorNumber= 0 THEN
      slSelAry sql,s(),"Q9c"
      gsResult+= JOIN$(s(),$CR) + $CR
      gsResult+= "Database open error" + $CR
    slDisconnect
    gsResult+="Could not connect" + $CR
