February 27, 2020, 05:18:47 am
How do you make holes in the windows firewall?
Started by Fim, December 21, 2016, 07:59:49 am
Fim
Running SQLitening server on PC on the network works fine.
J can connect to the server ONLY if I stop Windows firewall on the server-pc.
That is not good to run a PC without a firewall.
Someone who knows how to make "holes" in the Windows Firewall so that a client can communicate with SQLitening Server?
/Fim W.
Fim W
December 21, 2016, 12:50:07 pm #1 Last Edit: December 21, 2016, 12:59:47 pm by cj
In advanced settings have you created an inbound rule for the port?
I don't think that letting an app or feature through is necessary if an inbound rule is created.
http://sqlitening.com/support/index.php?topic=3402.msg17476#msg17476
I will test with Windows 10 if netsh is working.
These work with my Windows 10 machine to allow port 51234.
Created 2 batch files, but could easily be added to a program (things to do.)
rem syntax: PortOn.bat 51234
netsh advfirewall firewall delete rule name = %1 protocol=TCP localport=%1
netsh advfirewall firewall add rule name = %1 dir=in action = allow protocol=TCP localport=%1
rem syntax: PortOff.bat 51234
Fim
Thank you.
It thus makes a "hole" for that port 51234 via TCP and it seems pretty logical.
Test it tomorrow or next week.
/Fim  W
Fim W
December 21, 2016, 02:45:05 pm #4 Last Edit: December 30, 2016, 10:49:50 am by cj
Requires program run as administrator or has a manifest.
#RESOURCE manifest, 1,"manifest.xml"  'admin level
FUNCTION PBMAIN () AS LONG
  PortOff  51234   'delete previous entry in case it exists
  PortOn   51234   'add new entry
SUB PortOn(PortNum AS LONG)
  LOCAL s AS STRING
  s = "netsh advfirewall firewall add rule name = %1 dir=in action = allow protocol=TCP localport=%1
  REPLACE "%1" WITH FORMAT$(PortNum) IN s
  SHELL ENVIRON$("COMSPEC") + " /C "  + s,0
SUB PortOff(PortNum AS LONG)
  LOCAL s AS STRING
  s = ENVIRON$("COMSPEC") + " /C " + "netsh advfirewall firewall DELETE rule NAME = %1 protocol=TCP localport=%1"
'manifest.xml
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0">
    <asmv3:trustInfo xmlns:asmv3="urn:schemas-microsoft-com:asm.v3">
        <asmv3:security>
            <asmv3:requestedPrivileges>
                <asmv3:requestedExecutionLevel
                    level="requireAdministrator"
                    uiAccess="false"/>
            </asmv3:requestedPrivileges>
        </asmv3:security>
    </asmv3:trustInfo>
</assembly>
