SQLitening Error Code -13
Started by Fim, February 11, 2017, 08:51:37 AM
Fim
CJ,
You inspired me to use other forms of JOIN.
This works ok:
SELECT * FROM VOR;
even this
SELECT * FROM MTR;
But with this, I get -13
SELECT * FROM VOR, MTR;
Is it an error in SQLitening or something else?
/Fim W
Fim W
Fim
* cannot be used with multiple tables, but the columns needed can be listed.
That solv the problem.
Thanks a lot.
/Fim W.
Fim W
#2
Duplicate column names can be used.  Had to do some reading about the modchars of slSel.
slSel "SELECT * FROM VOR, MTR",0,"D"
'negative error codes are from SQLitening
'%SQLitening_InvalidColumnNameNumber = -13 - Invalid column name or number
slSel
ModChars:
