July 23, 2021, 08:50:07 PM
Next Highest Row Example
Started by cj, March 03, 2017, 04:29:59 PM
March 03, 2017, 04:29:59 PM Last Edit: March 03, 2017, 04:42:29 PM by cj
Demonstrate get and insert "next highest row" in a single sql statement
It may be useful to know what the new highest row will be before inserting a record
Handles problem getting correct next highest record of empty table using coalesce
If multi-user/threaded call within a transaction so next highest row is locked
#INCLUDE "sqlitening.inc" 'InsertNextHighestRow.Bas
FUNCTION PBMAIN () AS LONG
slOpen "cj.db3","C"
slexe "create table if not exists T1(C1 Integer Primary Key AutoIncrement,C2)"
DO
  REDIM sArray(0) AS STRING
  slSelAry "select * from T1",sArray$(),"Q9c E0"
  IF slGetErrorNumber = 0 THEN sResult$ = JOIN$(sArray$(),$CR) ELSE ? slGetError,,"slSelAry"
  IF MSGBOX(sResult$,%MB_YESNO,"Do you want to insert record " + GetNextHighestRow) <> %IDYES THEN
    EXIT DO
  slexe "insert into T1 values(null,(select 'Something '||(COALESCE(max(C1),0)+1) from T1))","E0"
  IF slGetErrorNumber THEN ? slGetError,,"Insert error"
LOOP
FUNCTION GetNextHighestRow AS STRING
slsel "select COALESCE(max(C1),0)+1 from T1",0,"E0"
  slGetRow
  FUNCTION = slf(1)
  ? slGetError,,LCASE$(FUNCNAME$)
