January 17, 2022, 09:09:18 PM
Embed Image Using SQLitening & DDOC
Started by Fredrick Ughimi, June 05, 2017, 12:57:31 PM
Fredrick Ughimi
Great! Thanks CJ.
Been distracted with other part of the application.
Working on allowing pathed files from client.
Fredrick Ughimi
Oh ok.
June 17, 2017, 05:44:56 PM #18 Last Edit: June 19, 2017, 10:41:00 AM by cj
This version still needs to write images back and forth to the local disk to load into ddoc, yuck.
Because of this the logic had to be changed for client/server.
This is fast without the server, but leaves something to be desired running on a server.
The %TestMode variable shows the pushing and popping the database back and forth between local/server.
I'm not sure if that is killing the performance.  I'll work on this more when time permits.
Switching between local and remote is now very safe, but not sure it is implemented well.
Need to investigate ddoc source or perhaps these links:
https://forum.powerbasic.com/forum/user-to-user-discussions/powerbasic-for-windows/53636-some-png-images-display-oddly?t=52321&highlight=GdipDrawImageRect
https://forum.powerbasic.com/forum/user-to-user-discussions/powerbasic-for-windows/49073-gdi-question?t=47870
https://forum.powerbasic.com/forum/user-to-user-discussions/source-code/52507-gdi-image-save-load-from-to-buffer
#COMPILE EXE
#DIM ALL
$Server = "192.168.0.2":%Port=0  'remark to run without server
%AddClients=20
%TestMode = 0  'messagebox each time switch between local and server mode
%ClientServerFlag = 9999
#INCLUDE "ddoc_p32.inc" 'requires ddoc32.dll and ddoc_jpg.dll
#INCLUDE "\sql\bin\sqlitening.inc"
THREADED ClientServer,CurrentMode AS LONG 'need to know when switching local/remote at all times
FUNCTION PBMAIN () AS LONG 'ddocsample3.bas
LOCAL x, AddClients AS LONG
#IF %DEF($Server)
slConnect $Server,%Port:ClientServer=%ClientServerFlag:CurrentMode=%ClientServerFlag
#ENDIF
slOpen "ddoc.db3","C"
IF %AddClients > 0 THEN
  slexe "drop table if exists ClientTable"
  slexe "drop table if exists ImageTable"
slexe "create table if not exists ClientTable(ClientKey integer primary key,ClientName)
slexe "create Table if not exists ImageTable(key UNIQUE, picture BLOB)"
  AddClients = %AddClients
  slexe "begin immediate"   'add some clients and images
  FOR x = 1 TO AddClients
   slexe USING$("insert into ClientTable values(null_,#)",x)
   AddImage "\arm\heidi3.bmp","ImageTable",FORMAT$(x)
  slexe "end"
? "Ready to TestDDoc",%MB_SYSTEMMODAL,"Created tables"
TestDDoc
'Test
FUNCTION TestDDoc AS LONG
LOCAL sql AS STRING
LOCAL x,y,x2,y2 AS SINGLE
LOCAL PrintPreview,DefaultZoom,TheBin,EndCode,iHandle,counter,hpix AS LONG
LOCAL docTitle   AS ASCIIZ * 66
LOCAL outputfile AS ASCIIZ * 66
LOCAL skey AS STRING
LOCAL sKeyArray() AS STRING
LOCAL result AS LONG
DIM sClientNumberArray() AS STRING   'get all client numbers into an array
sql =  "select ClientKey from ClientTable"
slselAry sql,sClientNumberArray(),"Q9"
IF UBOUND(sClientNumberArray) < 1 THEN ? "No clients":EXIT FUNCTION
#IF %DEF($Server)
DocTitle = "CLIENT/SERVER MODE " + $Server + " on port"' + STR$(%Port)
#ELSE
   docTitle = "LOCAL MODE"
#ENDIF
PrintPreview = 1
DefaultZoom = %DDOC_ZOOM75
TheBin = %DDOC_Bin_Auto
IF PrintPreview THEN
  endCode = %DDOC_END_VIEW + %DDOC_END_DELETE
  endCode = %DDOC_END_PRINT + %DDOC_END_DELETE
  DefaultZoom+= %DDOC_VIEWBUILD 'so no dialog will appear
ihandle = dpStartDoc(0,DocTitle,outputfile,%DDOC_INCH,%DDOC_PAPER_LETTER,%DDOC_SYSTEM_DEFAULT,TheBin,DefaultZoom + %DDOC_VIEWBUILD)
slSelAry sql,sKeyArray(),"Q9c"
IF slGetErrorNumber THEN ? slGetError,%MB_ICONERROR OR %MB_SYSTEMMODAL,"No images will print"
FOR counter = 1 TO UBOUND(sKeyarray)
  skey = skeyArray(counter)
  x =  0    'upper left column
  y  = 0    'upper left row
  x2 = 3    'low right column
  y2 = 5    'low right row
  result = slAddGraphic(iHandle,hpix,"ImageTable","picture",sKey,x,y,x2,y2)
  IF counter<> UBOUND(sKeyArray)THEN
   dpNewPage iHandle,  %ddoc_PAPER_A4, %DDOC_PORTRAIT, %DDOC_BIN_AUTO
dpEndDoc iHandle, EndCode
'SHELL ENVIRON$("COMSPEC") + " /C taskkill.exe /F /T /IM ddoc.exe",0
FUNCTION AddImage(sImageFile AS STRING,sImageTable AS STRING,sKey AS STRING) THREADSAFE AS LONG
LOCAL sBlob AS STRING
result = slGetFileLocal(sImageFile,sBlob)
IF result THEN EXIT FUNCTION
FUNCTION = BlobToTable(sImageTable,sKey,sBlob)
FUNCTION BlobToTable(sImageTable AS STRING,sKey AS STRING,sBlob AS STRING) AS LONG
slExeBind "Replace into " + sImageTable + " values(?,?)", _
                                  slBuildBindDat(sKey,"T") + _
                                  slBuildBindDat(sBlob)
IF slGetChangeCount <> 1 THEN
   ? "Image key " + sKey,,"slPutImage Error"
   FUNCTION = 1
FUNCTION slGetImageFromTable(sImageTable AS STRING,sImageColumn AS STRING, sKey AS STRING) AS STRING
LOCAL sql AS STRING, counter AS LONG
slSetProcessMods "E2"
sql = "select " + sImageColumn + " from " + sImageTable + " where key ='" + sKey + "'"
slsel sql
IF slGetRow THEN FUNCTION = slf(1) ELSE ? "key not found" + $CR + sql,,FUNCNAME$:EXIT FUNCTION
FUNCTION slGetFileLocal(sImageFile AS STRING,sBlob AS STRING) THREADSAFE AS LONG
LOCAL ModeBeforeHere AS LONG
ModeBeforeHere = CurrentMode
IF ModeBeforeHere <> 0 THEN SwitchLocal 'we must be local mode
FUNCTION = slGetFile(sImageFile,sBlob,"C E0")
IF ModeBeforeHere = %ClientServerFlag THEN SwitchRemote 'switch back to remote
FUNCTION slPutFileLocal(sTempFile AS STRING,sBlob AS STRING) THREADSAFE AS LONG
LOCAL ModeBeforeHere,result AS LONG
FUNCTION = slPutFile(sTempFile,sBlob,"CT E0")
IF slGetErrorNumber THEN ? slGetError,,FUNCNAME$
FUNCTION slAddGraphic(iHandle AS LONG,hPix AS LONG,sImageTable AS STRING,sImageColumn AS STRING,sKey AS STRING, _
                      x AS SINGLE,y AS SINGLE,x2 AS SINGLE,y2 AS SINGLE) AS LONG
  LOCAL sTempFile      AS STRING
  sBlob = slGetImageFromTable(sImageTable,sImageColumn,sKey)
  IF LEN(sBlob) = 0 THEN
    BEEP
    '? "zero length blob",,FUNCNAME$
    FUNCTION = 98
  sTempFile = FORMAT$(TIMER) + ".tmp"
  result = slPutFileLocal(sTempFile,sBlob)  '6/11/17 wrap in threadsafe transaction
  FUNCTION = result
  IF result THEN
    ? "slPutError" + STR$(result),,FUNCNAME$
  hpix = dpAddGraphic(ihandle,sTempFile+$NUL)
  KILL sTempFile
  IF hpix THEN
   dpDrawGraphic ihandle, hpix,x,y,x2,y2 'these values should be passed
   ? "Error getting graphic " + sTempFile,%MB_SYSTEMMODAL,FUNCNAME$
SUB SwitchLocal THREADSAFE
IF CurrentMode = 0 THEN EXIT SUB 'aleady in local mode
IF %TestMode THEN ? FUNCNAME$
slPushDatabase
slSetProcessMods "L0"
currentMode = 0
SUB SwitchRemote THREADSAFE
IF CurrentMode = %ClientServerFlag THEN EXIT SUB 'already in remote mode
slPopDatabase
slSetProcessMods "L1"
Fredrick Ughimi
Fredrick Ughimi
Hello,
Been thinking.
I normally read images from the SQLitening Database and place them on the Picture Control. Like this:
sPicture = slFN("Picture")
VD_IPictureBox_LoadImageByMem(hfrmDPRRegistrationForm, %ID_FRMDPRREGISTRATIONFORM_VD_IPICTUREBOX1, StrPtr(sPicture), Len(sPicture))
I wish I could just use it to place the image on DDOC. Is there anyway to use it with dpAddGraphic?
Best regards,
Fredrick Ughimi
VD_IPictureBox_LoadImageByMem() is wrapper function for PwrDev.
Fredrick Ughimi
June 30, 2017, 06:18:05 PM #22 Last Edit: June 30, 2017, 06:24:14 PM by Fredrick Ughimi
Hello CJ,
I am thinking of storing the images in a disk file.
The thing is, I am printing a Picture and a Name on the same page and can't figure out how to correctly match the appropriate Picture with the Name if the images are stored in disk file. I intend printing multiple pages at a go using a BatchNo.
Any ideas? Thank you for your responses.
Best regards,
How about an index to the locations in the flat file with any captions, titles, date you need by using a Table
slexe "create Table if not exists LocateImageTable(key UNIQUE, StartByteColumn,LengthColumn)"
Fredrick Ughimi
Hello CJ.
I guess this is in response to my last post before this.
Its a bit confusing. A flat file using a Table like in SQLite?
Associate the picture and name with the starting byte in the file.
The table used to be an index to the file can contain anything and even the image.
Fredrick Ughimi
Hello CJ,
How do I read the disk file in DDOC?
My attemp...
#COMPILE EXE
#DIM ALL
#INCLUDE "sqlitening.inc"
#INCLUDE "DDOC_P32.INC"
GLOBAL sFileName AS STRING
%vbBlack = &H0&
  LOCAL sPicture, sPixNamePath, sPixName, sCertificateNo, sName, sBatchNo AS STRING
  LOCAL Errorcode&
  sCertificateNo = "309"
  sName = "Mark Ogbe"
  sBatchNo = "122"
  sFileName = "PictureX"
  slOpen ("CharkinDB.db3","C")
  slExe BUILD$("Create Table If Not Exists tblDPRReg(CertificateNo TEXT, Name TEXT, BatchNo TEXT, PixName TEXT, Picture BLOB)")
  slExe "Create UNIQUE Index If Not Exists DPRRegndx ON tblDPRReg(CertificateNo)"
  sPixName = "Ughimi.jpg"
  sPixNamePath = "C:\Charkin ERP\Pictures\" & sPixName
   slGetFile sPixNamePath, sPicture, "E1" '9216 bytes
        Errorcode& = slExeBind(slBuildInsertOrUpdate("tblDPRReg", "?" & $NUL & "?" & $NUL & "?" & $NUL & "?" & $NUL & "?"), _
          slBuildBindDat(sCertificateNo, "T") & _
          slBuildBindDat(sName, "T") & _
          slBuildBindDat(sBatchNo, "T") & _
          slBuildBindDat(sPixName, "T") & _
          slBuildBindDat(sPicture, ("B")),"E")
          slPutFile sFileName, sPicture, "C"
          ReportCertificate()
FUNCTION ReportCertificate() AS LONG
      LOCAL LineSpacing!,iHandle%,Row!,TopMargin!,PageSize!,PageNumber&
      LOCAL detailline AS ASCIIZ * 200
      LOCAL SNo AS LONG
      LOCAL sBatchNo AS STRING
      LOCAL hpix AS LONG
      LineSpacing = .2
      TopMargin   = .5
      PAGESIZE    = 10
      ihandle% = dpStartDoc(0,"Mega-Net CharkinERP - Certificate Report","",%DDOC_INCH, %DDOC_PAPER_A4, %DDOC_PORTRAIT, %DDOC_SYSTEM_DEFAULT, %DDOC_BIN_AUTO OR %DDOC_ALLOWSMTP OR %DDOC_ALLOWSAVE OR %DDOC_ZOOMFIT)
      IF ihandle < 1 THEN
           MSGBOX "Could not StartDoc. Error number" + STR$(Ihandle)
           GOTO EndProgram
      dpSetTabs iHandle, "L.5W1 L1.1W1 L2.5W4 L5.5W2"
      ROW = PAGESIZE                            'force new heading
      sBatchNo = "122"
     slSel "SELECT * FROM tblDPRReg WHERE BatchNo = '" + sBatchNo  + "'"
     DO WHILE slGetRow()
        IF ROW => PAGESIZE THEN
           IF PageNumber THEN      'If first page don't need a new page
              dpNewPage iHandle%,  %ddoc_PAPER_A4, %DDOC_PORTRAIT, %DDOC_BIN_AUTO
           INCR PageNumber
           dpFont ihandle%, %DDOC_FONTNORMAL + %DDOC_FONTBOLD, 20, %vbBlack, "Arial"
           dpText IHandle%, 4.25, 4.6, %DDOC_CENTER, "" + slFN("Name")
           hpix = dpAddGraphic(ihandle%, EXE.PATH$ & "PictureX.dat") ' This is where I am having issues
           IF hpix THEN
              dpDrawGraphic ihandle%, hpix,6.4,6.1,7.8,11
           'dpFont ihandle%, %DDOC_FONTNORMAL + %DDOC_FONTUNDERLINE + %DDOC_FONTBOLD, 10, %vbBlack, "Arial"
           'dpTabText iHandle%, Row + .7, "S/No" + $Tab + "CourseCode" + $Tab + "Course" + $Tab + "Amount"
           dpFont ihandle%, %DDOC_FONTNORMAL, 9, %vbBlack, "San Serif"
           ROW =  ROW + LineSpacing * 2
        ROW = ROW + LineSpacing                    'increment line counter
      LOOP
      dpEndDoc iHandle%, %DDOC_END_VIEW + %DDOC_END_PRINT
    EndProgram:
