Saving Images Remotely
Started by Fredrick Ughimi, August 12, 2017, 12:07:14 PM
Fredrick Ughimi
Hello,
On a Client/Server arrangement I guess its ok to load images from a
sub directory of the client computer i. e C:\ClientFiles\Pictures
and saved on the remote SQlitening Database.
I get a error "-8 Access Denied" and sometimes I get "-9 - File does not exit"
m_sPixNamePath = Exe.Path$ & "Pictures\" & m_sPixName
slGetFile m_sPixNamePath, m_sPicture, "E1" '9216 bytes
Is there a way around this?
Fredrick Ughimi
Thanks CJ.
Tried out the codes in my program and I got a crash. Same thing happened when I ran it on the PB IDE.
#COMPILE EXE
#DIM ALL
#INCLUDE "sqlitening.inc"
FUNCTION PBMAIN () AS LONG
    LOCAL sServer AS STRING
    LOCAL sPort AS STRING
    LOCAL sErr AS STRING
    LOCAL Errorcode&
    sServer = "MegaNetSoftware"
    sPort = "Default"
    slConnect(sServer, VAL(sPort))
    sErr = slGetError
    IF VAL(sErr) <> 0 THEN
         MSGBOX sErr, %MB_TASKMODAL OR %MB_ICONINFORMATION, EXE.NAME$
   slOpen ("CharkinERPDB.db3","C")
LOCAL m_sPixNamePath AS STRING
LOCAL m_sPixName     AS STRING
LOCAL m_sPicture     AS STRING
m_sPixnamePath = EXE.PATH$ & "Pictures\"
m_sPixName     = "Ughimi.jpg"
slSetProcessMods "L0"
slGetFile m_sPixnamePath & m_sPixName,m_sPicture,"E1"
IF slGetErrorNumber = 0 THEN ? USING$("image length #,",LEN(m_sPicture))
Errorcode& = slExeBind(slBuildInsertOrUpdate("tblDPRRegistration", "?"), _
slBuildBindDat(m_sPicture, ("B")))
#2
Note: Switching between local mode (L0) and remote mode (L1) can be eliminated using GET or GET$ instead of slGetFile reading local .jpg files.
SQlite suggests storing images in a table rather than pointing to there location.
One article mentions that the opening and closing of individual files may take longer than accessing from the database!
I'm curious if attaching to a separate database might have some advantages, but haven't yet found any articles on doing it.
https://sqlite.org/intern-v-extern-blob.html
https://sqlite.org/fasterthanfs.html#read_performance_measurements
Others don't agree storing images in tables (at least the main table.)
https://www.quora.com/Is-it-a-bad-design-to-store-images-as-blobs-in-a-database
Example getting local files without using slSetProcessMods "L0" or slGetFile to stay in remote mode and sent files from local machine.
http://sqlitening.com/support/index.php?topic=9675.0
LOCAL sServer,sPathName,sFilename,sBlob AS STRING
slSetProcessMods "E0"
sServer   = "ip_or_machinename"
sPathName = "my_local_pictures\"
sFileName = "my.jpg"
slconnect sServer
IF slGetErrorNumber THEN ? sServer,%MB_SYSTEMMODAL,"Connect Error":EXIT FUNCTION
slOpen ("mydatabase.db3","C")
slexe "create table if not exists PictureTable(filename unique,blob)"
slSetProcessMods "L0"                    'switch to local processing
slGetFile sPathname + sFilename,sBlob    'get .jpg into a string sBlob$ from local disk
IF slGetErrorNumber = 0 THEN             'if no error
  WriteBlobRemote sFileName,sBlob         'switches to remote processing in SUB and inserts or updates Sqlite table
  GetBlobRemote  sFileName                'just testing (not needed) switches to remote processing in SUB and gets from SQlite table
  ? slGetError,,sFilename
slSetProcessMods "L1" 'prevent possible slDisconnect crash if not in remote mode
slDisconnect
SUB WriteBlobRemote(sFileName AS STRING,sBlob AS STRING)
LOCAL NumberOfChanges AS LONG
NumberOfChanges = slGetChangeCount("T")
slexeBind "replace into PictureTable values('" + sFileName + "',?)",slBuildBindDat(sBlob)
   ? slGetError,%MB_SYSTEMMODAL,"WriteBlobRemote"
   EXIT SUB
NumberOfChanges = slGetChangeCount("T") - NumberOfChanges
IF NumberOfChanges <> 1 THEN ? "Picture could not be written"
SUB GetBlobRemote(sFileName AS STRING)
slSel "select filename,blob from PictureTable where filename ='"+sFilename + "'"
  ? slGetError,,"Show Blob Remote"
  EXIT SUB
IF slGetRow THEN
  ? USING$("&   #, bytes",slf(1),LEN(slf(2))),%MB_SYSTEMMODAL,"Picture"
  ? sFileName,,"Remote Blob Not Found"
Fredrick Ughimi
Hello CJ,
Keeping track of the images in a directory by using a pointer or storing in the database?
I can't decide, but if storing remotely they will still have to be accessed in the remote location and use slGetFile.
I think I would try just putting in another table and if it slows things down go the pointer route.
Storing in a table would seem simplier and more efficient to me.
Might as well continue on this part until I complete the project.  If the images slows things down later I would go the pointer route.
What advantages would it present if images are stored in a different table?
Fredrick Ughimi
CJ,
By the way, the picture table above is already a separate table.
Yeah. I am thinking of the best way to link the images table with the main table. Use the image name or an IDNo.
Fredrick Ughimi
Hello CJ,
I have been able to adapt your code to my project:
This worked great while I am saving the records.
  'Pictures
        m_sPixName = VD_GetText (hfrmDPRRegistrationForm, %ID_FRMDPRREGISTRATIONFORM_TXTPICTURENAME)
        slGetFile m_sPixnamePath + m_sPixName, m_sPicture,"E1"
        slSetProcessMods "L1" 'prevent slDisconnect failing if a local error occurred
But I am still getting error -8 - Access Denied while reporting.
Reporting, done locally?  Did you return to local mode using slSetProcessMods "L0" before reporting?
Does the server and the local machine use the same version of SQLite?
%SQLitening_AccessDenied =  -8 - Access denied
Insufficent code to see where you connect and open database and get image
  'Pictures
        GetBlobRemote(m_sPicture)
        'process locally
        'slSetProcessMods "L1"
         slDisconnect
Fredrick Ughimi
CJ,
Reporting is done remotely.
Yes. I returned to local mode using slSetProcessMods "L0" before reporting. Sorry, I get  - error 21. See attached.
Method ReportCertificateOfTrainingInAdvancedRiggingAndLiftingGearInspectionCourse(ByVal nCbHndl As Long) As Long
      Local LineSpacing!,iHandle%,Row!,TopMargin!,PageSize!,PageNumber&
      Local detailline As Asciiz * 200
      Local sBatchNo As String
      Local hpix As Long
      Local sTempImageFile As String
      Local sTempSignatureFile As String
      Local hSignature As Long
      Local sBind As String
      LineSpacing = .2
      TopMargin   = 0
      PAGESIZE    = 11.4
      ihandle% = dpStartDoc(0,"Mega-Net CharkinERP - Print Certificate of Training in Advanced Rigging and Lifting Gear Inspection Course","",%DDOC_INCH, _
      %DDOC_PAPER_CUSTOM, %DDOC_PORTRAIT, %DDOC_SYSTEM_DEFAULT, %DDOC_BIN_AUTO Or %DDOC_ALLOWSMTP Or %DDOC_ALLOWSAVE Or %DDOC_ZOOMFIT)
      If ihandle < 1 Then
           MsgBox "Could not StartDoc. Error number" + Str$(Ihandle),%MB_TASKMODAL Or %MB_ICONINFORMATION,VD_App.Title
           Exit Method
      dpPaperSize ihandle%, 8.0,11.4
      ROW = PAGESIZE                            'force new heading
      ReportsInformation()
     sBatchNo = VD_GetText(nCbHndl, %ID_FRMCERTIFICATEOFTRAININGINADVANCEDRIGGINGANDLIFTINGGEARINSPECTIONCOURSERPTDLG_TXTBATCHNO)
     slSEL "SELECT * FROM tblDPRRegistration WHERE BatchNo = '" + sBatchNo + "'"
     Do While slGetRow()
        sTempImageFile=GuidTxt$(Guid$) + ".jpg"    'change 2
        slPutFile sTempImageFile, slFN("Picture"), "C"  '25th column 'change 3
        sTempSignatureFile=GuidTxt$(Guid$) + ".jpg"    'change 2
        slPutFile sTempSignatureFile, slFN("Signature"), "C"  '27th column 'change 3
        If ROW => PAGESIZE Then
           If PageNumber Then      'If first page don't need a new page
              dpNewPage iHandle%, %DDOC_PAPER_CUSTOM, %DDOC_PORTRAIT, %DDOC_BIN_AUTO
           Incr PageNumber
           dpFont ihandle%, %DDOC_FONTNORMAL + %DDOC_FONTBOLD, 20, %vbBlack, "Arial"
           dpText IHandle%, 3.1,2.0, %DDOC_LEFT, "" + slFN("CertificateNo")
           dpText IHandle%, 2.9, 3.5, %DDOC_LEFT, "" + slFN("FirstName") & " " & slFN("Surname")  & " " &  slFN("Othernames")
           dpFont ihandle%, %DDOC_FONTNORMAL + %DDOC_FONTBOLD, 12, %vbBlack, "Arial"
           dpText IHandle%, 3.0,4.35, %DDOC_LEFT, "" + NigeriaDate(slFN("BirthDate"))
           dpText IHandle%, 5.7,8.6, %DDOC_LEFT, "" + NigeriaDate(slFN("Signature"))
           dpText IHandle%, 2.6,8.3, %DDOC_LEFT, "" + NigeriaDate(slFN("CourseEndDate"))
           hpix = dpAddGraphic(ihandle%, sTempImageFile+$Nul)
           Kill sTempImageFile  'change 5
           If hpix Then
              dpDrawGraphic ihandle%, hpix,5.9,6.9,7.1,8.2
           Else
            ? "Picture not found",%MB_TASKMODAL Or %MB_ICONINFORMATION,Exe.Name$
           hSignature = dpAddGraphic(ihandle%, sTempSignatureFile+$Nul)
           Kill sTempSignatureFile  'change 5
           If hSignature Then
              dpDrawGraphic ihandle%, hSignature,4.1,6.8,5.6,7.0
           Else
            ? "Signature not found",%MB_TASKMODAL Or %MB_ICONINFORMATION,Exe.Name$
           ROW =  ROW + LineSpacing * 2
        ROW = ROW + LineSpacing                    'increment line counter
      Loop
   dpEndDoc iHandle%, %DDOC_END_VIEW + %DDOC_END_PRINT
End Method
Fredrick Ughimi
I still use PwrDev IDE, so my codes are not one place.
'Connect/Open
    sPort = "Default"
    slConnect(sServer, Val(sPort))
    sErr = slGetError
    If Val(sErr) <> 0 Then
         MsgBox sErr, %MB_TASKMODAL Or %MB_ICONINFORMATION, VD_App.Title
         Exit Function
   Get Image:
        Errorcode& = slExeBind(slBuildInsertOrUpdate("tblDPRRegistration", "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & _
        "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & _
        "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?" & $Nul & "?"), _
          slBuildBindDat(SQLiteDate(m_sDate), "T") & _
          slBuildBindDat(m_sBatchNo, "T") & _
          slBuildBindDat(m_sIDMeans, "T") & _
          slBuildBindDat(m_sIDNo, "T") & _
          slBuildBindDat(m_sFirstName, "T") & _
          slBuildBindDat(m_sSurname, "T") & _
          slBuildBindDat(m_sOthernames, "T") & _
          slBuildBindDat(SQLiteDate(m_sCourseStartDate), "T") & _
          slBuildBindDat(SQLiteDate(m_sCourseEndDate), "T") & _
          slBuildBindDat(SQLiteDate(m_sExpiryDate), "T") & _
          slBuildBindDat(m_sCourseCode, "T") & _
          slBuildBindDat(m_sEmailAddress, "T") & _
          slBuildBindDat(m_sCertificateNo, "T") & _
          slBuildBindDat(m_sCorrAddress, "T") & _
          slBuildBindDat(SQLiteDate(m_sBirthDate), "T") & _
          slBuildBindDat(m_sBirthPlace, "T") & _
          slBuildBindDat(m_sSponsor, "T") & _
          slBuildBindDat(m_sDepartment, "T") & _
          slBuildBindDat(m_sEmployeeIDNo, "T") & _
          slBuildBindDat(m_sNationality, "T") & _
          slBuildBindDat(m_sOccupation, "T") & _
          slBuildBindDat(m_sPhoneNo, "T") & _
          slBuildBindDat(m_sKinName, "T") & _
          slBuildBindDat(m_sKinPhoneNo, "T") & _
          slBuildBindDat(m_sPixName, "T") & _
          slBuildBindDat(m_sPicture, ("B")) & _
The data is on the server, but where do you get it?
You are in local mode.
Fredrick Ughimi
Here:
Fredrick Ughimi
Is there a reason to keep requesting local routines?
     Do While slGetRow()
I forgot to remove the second slSetProcessMods "L0". My mistake.
When I run the application with the correction made, I now get crash.
Fredrick Ughimi
I am running the application on a remote mode.
