July 23, 2021, 07:30:42 PM
Write files without slGetFile and slPutFile to blobs 4 Helper functions
Started by cj, August 16, 2017, 10:13:44 PM
Using normal PowerBASIC file handling to read local files can eliminate having to load and unload SQLitening routines
if a program is accessing both local flat files and a remote database using the SQLitening server routines.
Using GetLocalFile(sFileName,sData)  and PutLocalFile(sFileName,sData) instead of slGetFile and slPutFile
can eliminate the need to use slSetProcessMods "L0" and slSetProcessMods "L1".
To make more robust need to add TableName and BlobColumnName parameters to GetBlob and PutBlob (to do list) which would match names in create statement.
The PutBlob(sKey,sData) function replaces the data if found or inserts the data if not found.
4 Helper functions:
FUNCTION PutBlob(sBlobKey AS STRING,sBlob AS STRING) THREADSAFE AS LONG
FUNCTION GetBlob(sBlobKey AS STRING,sBlobData AS STRING) THREADSAFE AS LONG
FUNCTION GetLocalFile(sFileName AS STRING, sData AS STRING) THREADSAFE AS LONG
FUNCTION PutLocalFile(sFileName AS STRING, sData AS STRING) THREADSAFE AS LONG
As always, comments welcome!
#INCLUDE "sqlitening.inc"
FUNCTION PBMAIN() AS LONG
LOCAL sLocalFileName,sLocalData,sData,sKey AS STRING, eCode AS LONG
'create local test file which will later be saved into a SQLitening blob column
sLocalFileName="test.txt"
OPEN sLocalFileName FOR OUTPUT AS #1:PRINT #1,"If you read this, it worked!!":CLOSE
slconnect "think.freemyip.com",47381
slOpen    "Test.db3","C"                          'database to open
slexe     "create table if not exists PictureTable(blobkey unique,blobdata)"
'read local file
eCode = GetLocalFile(sLocalFileName,sLocalData)
IF eCode THEN ? "GetLocalFile error" + STR$(eCode),%MB_SYSTEMMODAL,"GetLocalFile Error"
'save data to server using key
sKey  = "Heidi Klum"                              'get and save key
eCode = PutBlob(sKey,sLocalData)
IF eCode THEN ? slGetError,%MB_SYSTEMMODAL,"WriteBlob"           :EXIT FUNCTION
'read data from server
eCode = GetBlob(sKey,sData)
IF eCode THEN ? slGetError,%MB_SYSTEMMODAL,"Getblob"             :EXIT FUNCTION
? sData,%MB_SYSTEMMODAL,"GetBlob"
slDisconnect
eCode = PutLocalFile("junk.txt",sData)            'write data to a local file
IF eCode THEN ? "PutLocalFile error" + STR$(eCode),%MB_SYSTEMMODAL,"PutLocalFile":EXIT FUNCTION
eCode = GetLocalFile("junk.txt",sLocalData)
? sData,%MB_SYSTEMMODAL,"GetLocalFile"
LOCAL NumberOfChanges AS LONG 'function returns 0 on success
NumberOfChanges = slGetChangeCount("T")
slexeBind "replace into PictureTable values('" + sBlobKey + "',?)",slBuildBindDat(sBlob)
IF slGetErrorNumber THEN
   FUNCTION = slGetErrorNumber
NumberOfChanges = slGetChangeCount("T") - NumberOfChanges
IF NumberOfChanges <> 1 THEN FUNCTION = -9999
sBlobData = ""   'function returns 0 on success
slSel "select blobdata from PictureTable where blobkey ='"+sBlobKey + "'"
IF slGetRow THEN sBlobData = slf(1)
sData = "" 'function returns 0 on success
LOCAL MaxRetry AS LONG
LOCAL hFile AS LONG
IF ISFALSE(ISFILE(sFileName)) THEN 'local file not found
  FUNCTION = 53                'set error 53, file not found
  EXIT FUNCTION                'exit function
hFile = FREEFILE              'file handle
FOR MaxRetry = 1 TO 10        'maximum 10 attempts to open
  ERRCLEAR                     'clear error
  OPEN sFileName FOR BINARY ACCESS READ LOCK WRITE AS #hFile 'block writers
  IF ERR THEN                  'open error
   SLEEP 500                   'wait
   ITERATE                     'retry open
  GET$ #hFile,LOF(hFile),sData 'read data
  FUNCTION = ERR               '0 if success
  CLOSE #hFile                 'close file
  EXIT FOR
FUNCTION = ERR                '10 attempts to open reached
LOCAL hFile AS LONG
  OPEN sFileName FOR OUTPUT AS #hFile 'exclusive
   SLEEP 500                   'wait
   ITERATE                     'retry open
  PRINT #hFile, sData;         'write data
  EXIT FOR
slconnect "sqlitening.freemyip.com"
'read local file
sKey  = "Heidi Klum"
slDisconnect
LOCAL hFile AS LONG
   SLEEP 500                   'wait
   ITERATE                     'retry open
  EXIT FOR
LOCAL hFile AS LONG
   SLEEP 500                   'wait
   ITERATE                     'retry open
  EXIT FOR
