July 05, 2020, 07:18:38 am
Database Maintenance
Started by Fredrick Ughimi, November 22, 2017, 06:45:52 pm
Fredrick Ughimi
November 22, 2017, 06:45:52 pm Last Edit: November 22, 2017, 06:49:44 pm by Fredrick Ughimi
Hello,
I am trying to delete duplicate records in tblBioData from HospitalProDB.
#COMPILE EXE
#DIM ALL
#INCLUDE "SQLitening.Inc"
FUNCTION PBMAIN () AS LONG
    slOpen ("HospitalProDB.db3")
    slExe "Begin"
        slEXE "delete from tblBioData where rowid not in(select  min(rowid) from tblBioData group by HospitalNo, PhoneNo)
    slExe "End"
   ? "Duplicates Deleted!"
Then try to copy RowID to HospitalNo Column:
#COMPILE EXE
#DIM ALL
#INCLUDE "SQLitening.INC"
    slExe "Begin"
        slEXE "update tblBioData set HospitalNo = RowID"
    slExe "End"
    MSGBOX "Column Copied Successfully!", %MB_TASKMODAL OR %MB_ICONINFORMATION, "Mega-Net HospitalPro"
I still get error 19 - HospitalNo and PhoneNo not unigue.
Any suggestion would be appreciated
No data, no table, no database to test.
Also, nothing to compile.
Fredrick Ughimi
November 23, 2017, 02:55:00 pm #2 Last Edit: November 26, 2017, 03:37:16 am by Fredrick Ughimi
Hello CJ,
I had wanted to attach the database. Electricity issues did not allow me to (I live in Africa).
Anyway here is the attached database.
#COMPILE EXE
#DIM ALL
    slExe BUILD$("Create Table If Not Exists tblBioData(HospitalNo INTEGER primary key autoincrement, Registration TEXT, Title TEXT, Surname TEXT COLLATE NOCASE, Othernames TEXT COLLATE NOCASE,", _
      "DateCreated TEXT, PhoneNo TEXT, Email TEXT, HomeAddress TEXT, OfficeAddress TEXT, Company TEXT, Occupation TEXT, Sex TEXT, Age INTEGER, AgeClass TEXT,", _
      "MaritalStatus TEXT, BirthDate TEXT, Religion TEXT, StateOrigin TEXT, Tribe TEXT, EnroleeNo TEXT, Category TEXT COLLATE NOCASE, Plan TEXT, Entitlements TEXT, EnroleeExpiry TEXT,", _
      "HMOName TEXT, LGA TEXT, BirthPlace TEXT, Nationality TEXT, PixName TEXT, KinName TEXT, KinPhone TEXT, KinEmail TEXT, KinAddress TEXT, Relationship TEXT, Username TEXT, Picture BLOB)")
    slExe "Create UNIQUE Index If Not Exists BioDatandx1 ON tblBioData(HospitalNo, PhoneNo)"
    slExe "Create Index If Not Exists BioDatandx2 ON tblBioData(Surname, Othernames, DateCreated)"
    slExe "Begin"
    slExe "End"
    ? "Duplicates Deleted and Column Copied Successfully!"
Regards.
November 24, 2017, 11:01:30 am #3 Last Edit: November 26, 2017, 03:14:05 pm by cj
Please let me know if this posting is of any help since I'm confused about what to do after removing duplicates.
Please delete the .ZIP file updated because only needed to figure out what you are doing.
HospitalNo and rowid are the same since HospitalNo was defined integer primary key autoincrement
You know how to delete the duplicate entries so not sure what you want to do?
Reorder the rowids which are the same as the HospitalNo?
Your logic correctly deletes duplicate rowid/hospitalno based upon other columns
So, no more duplicate hospital/rowid's
Just assuming what to do for here on and wrote a test program to delete records
Left with rowid 1,3 after removing duplicates in this example and could be made 1,2 which does nothing.
Since all that I can think of doing is reordering the rowids:
copy originaltable to newtable, rename originaltable oldtable, rename newtable originaltable
or easier
for x = 1 to max(rowid)
  if x = hospitalno then incr counter:hospitalno = counter:update
next
If HospitalNo is renamed all other tables pointing to original table will be wrong.
Bottom line,  looks like you did everything correct and not sure what final update is for?
Only wanting unique HospitalNo could be:
After using index to delete duplicates, drop it and redefine as UNIQUE.
CREATE UNIQUE INDEX MyIndexName ON tblBioData(columnX,ColumnY,ColumnZ)
or
Use an ON CONFLICT with original table
Wrote this small example to test removing duplicates using same logic and it works.
#INCLUDE "sqlitening.inc"
LOCAL s AS STRING
KILL "test.db3"
slOpen "test.db3","C"
slexe "create table t1(HospitalNo integer primary key autoincrement,c2)"
slexe "insert into t1 values (1,'a')"
slexe "insert into t1 values (2,'a')"
slexe "insert into t1 values (3,'b')"
slexe "insert into t1 values (4,'a')"
slexe "insert into t1 values (5,'a')"
slexe "delete from t1 where HospitalNo not in(select min(HospitalNo) from t1 group by c2)"
sql   "select * from t1" 'rows 1 and 3 are unique
SUB sql(sSql AS STRING)
DIM sRecordSet() AS STRING
slselAry sSQL,sRecordSet(),"Q9c"
? JOIN$(sRecordSet(),$CR),,sSQL    'result 1 and 3 remaining after deleting duplicates
Fredrick Ughimi
Hello CJ,
Thank you for your response.
In reality not really. The HospitalNo column was not originally defined that way (integer primary key autoincrement). It was an after thought, it did even work and then abandoned the thought was I read about the negative implications. I just forgot to remove the integer primary key autoincrement part thereafter.
The point I am trying to make is that after removing duplicates, I still get error 19 - HospitalNo and PhoneNo not unigue when I run the code below:
November 26, 2017, 11:26:29 am #5 Last Edit: November 26, 2017, 03:11:10 pm by cj
Example of how it could occur:
KILL "junk.db3"
slOpen "junk.db3","C"
slexe "create table tblBioData(HospitalNo INTEGER,PhoneNo TEXT)"
slexe "insert into tblBioData values(2,'same')"  'no problem will be changed to 1
slexe "insert into tblBioData values(1,'same')"  'later problem, can't  be changed to 1
This might do what you want
slexe "Alter table tblBioData RENAME TO OriginalTable"
slexe "create table temp AS select * from OriginalTable order by HospitalNo"
slexe "Alter table temp Rename To tblBioData"
Fredrick Ughimi
I think at this I would need to check if there are duplicate records:
#COMPILE EXE
#DIM ALL
    slOpen "HospitalProDB.db3","C"
    sql "Select * from tblBioData where (HospitalNo, PhoneNo) in (select HospitalNo, PhoneNo from tblBioData group by HospitalNo, PhoneNo having count(*) > 1 )"
Getting syntax error with that one.
Fredrick Ughimi
Thank you CJ,
This worked.
