September 16, 2021, 11:20:03 PM
Change Date Format
Started by Fredrick Ughimi, June 29, 2018, 07:57:39 AM
Fredrick Ughimi
Hello,
I have a table with records and a date column with the date format in this form: Thursday, April 27, 2017.
I would like to change it to 2017-04-27. Been having difficulties dealing with that date format.
Any ideas please.
Fredrick Ughimi
Tried the substr function and getting 443 error.
Changing from "dddd',' MMMM dd yyyy" to "yyyy-MM-dd"
slSEL "select substr(Date, 15,4) & "-" & substr(Date, 7,2) & "-" & substr(Date, 12,2) from tblSalesOrder"
Fredrick Ughimi
Hi Mike,
I guess my second response was a bit misleading. I want the values of the Date column which are in "dddd',' MMMM dd yyyy" format to "yyyy-MM-dd" format for instance  "Friday, June 29, 2018" to "2018-06-29". No time. I guess slSEL won't do it. I used slEXE no change either.
Fredrick Ughimi
Nothing changed. The Date column still contains dates with this format: "dddd',' MMMM dd yyyy". Over fourteen thousand records in there.
#COMPILE EXE
#DIM ALL
#include "SQLitening.inc"
FUNCTION PBMAIN () AS LONG
slOpen ("PepperoniERPDB.db3","C")
'SalesOrder
   slExe Build$("Create Table If Not Exists tblSalesOrder (TicketNo TEXT, Date TEXT, PricingScheme TEXT COLLATE NOCASE, AdultPrice REAL,", _
   "AdultDiscount REAL, AdultQuantity INTEGER, ChildPrice REAL, ChildDiscount REAL, ChildQuantity INTEGER, Movie TEXT, TotalAmount REAL,", _
   "PaymentMode Text, Event Text, Hall Text)")
   slExe "Create UNIQUE Index If Not Exists SalesOrderndx1 ON tblSalesOrder(TicketNo)"
   slExe "Create Index If Not Exists SalesOrderndx2 ON tblSalesOrder(PricingScheme, PaymentMode, Event)"
slExe "Begin"
     slsel "select date(Date) from tblSalesOrder"
slExe "End"
Fredrick Ughimi
June 29, 2018, 11:59:35 AM #4 Last Edit: June 29, 2018, 12:04:37 PM by Fredrick Ughimi
Hello CJ,
The format you using its quite differently from what I am referring to:
Yours: "yyyy-MM-dd HH:MM:SS" to "yyyy-MM-dd". Date() just extract the Date part.
Mine:  "dddd',' MMMM dd yyyy" to "yyyy-MM-dd". I want change the date data to "yyyy-MM-dd"
I think this should work, but I missing the correct syntax here:
Why is the  10-byte date not starting at position 1?
slSEL "select substr(Date,1,10) from tblSalesOrder"  'don't suggest using internal function names for column names
slSEL "select date(Date) from tblSalesOrder"
This is correct. 2018-06-29
What does your insert statement look like? slexe "insert into t1 values(current_timestamp)"
#INCLUDE "sqlitening.inc"
LOCAL sArray() AS STRING
slOpen "junk.db3","C"
slExe "Create Table If Not Exists t1 (TicketNo TEXT, DT)
slexe "insert into t1 values('myticket',current_timestamp)"
slselAry "select ticketno,date(DT) from t1",sArray(),"Q9c"
? JOIN$(sArray(),$CR)
slExe "Create Table If Not Exists t1 (Date)
slselAry "select date(Date) from t1",sArray(),"Q9c"
? JOIN$(sArray(),$CR) '2018-06-29
slselAry "select substr(date,1,10) from t1",sArray(),"Q9c"
Fredrick Ughimi
slExe "Begin"
            Errorcode& = slExe(slBuildInsertOrUpdate("tblSalesOrder", m_sTicketNo & $Nul & m_sDate & $Nul & m_sPricingScheme & $Nul & _
            m_sAdultPrice & $Nul & m_sAdultDiscount & $Nul & m_sAdultQuantity & $Nul & m_sChildPrice & $Nul & m_sChildDiscount & $Nul & _
            m_sChildQuantity & $Nul & m_sMovie & $Nul & m_sTotalAmount & $Nul & m_sPaymentMode  & $Nul & m_sEvent & $Nul & m_sHall),"E")
        slExe "End"
[/quote]
Fredrick Ughimi
Hello CJ,
Should have said "How is the data formatted that is passed in the m_sDate variable?"
Is it in a SQLite date format so it is displayed in a SQLite format?
"dddd',' MMMM dd yyyy" i.e. Sunday, July 01, 2018.
Fredrick Ughimi
Hello,
As a result of the long date format my Date column data looks like this:
Saturday, June 30, 2018
Monday, July 02, 2018
Tuesday, July 03, 2018
I want to change Date column data to:
2018-06-29
2018-06-30
2018-07-01
2018-07-02
2018-07-03
Because I am finding inconsistencies in querying the table when the Date column data remain
in "dddd',' MMMM dd yyyy" format as opposed to "yyyy-MM-dd" format.
slSel "SELECT * FROM tblSalesOrder WHERE Date BETWEEN '" + sFrom + "' AND '" +  sTo + "'"
Any ideas would be appreciated.
Fredrick Ughimi
Fredrick, Is there a function to convert from that format?
I tried writing one but it wasn't working as expected. Besides I would also have to deal with the date data format.
July 03, 2018, 09:04:44 PM #10 Last Edit: July 04, 2018, 07:53:40 PM by cj
Could be done in 1-pass, but would use the same logic.
Hope this gets you going.
GLOBAL gs AS STRING
FUNCTION PBMAIN ()
KILL    "junk.db3"
slopen  "junk.db3","C"
slexe   "create table if not exists t1(c1)"
slexe   "insert into t1 values('Friday, June 29, 2018')"
slexe   "insert into t1 values('Saturday, June 30, 2018')"
slexe   "insert into t1 values('Sunday, July 01, 2018')"
slexe   "insert into t1 values('Monday, July 02, 2018')"
slexe   "insert into t1 values('Tuesday, July 03, 2018')"
slexe   "insert into t1 values('Unknown, December 25, 2018')"
sl      "select rowid,c1 from t1"
slexe   "update t1 set c1 = substr(c1,-4) || '-01-' || substr(c1,-8,2) where instr(c1,'January') > 0"
slexe   "update t1 set c1 = substr(c1,-4) || '-02-' || substr(c1,-8,2) where instr(c1,'February') > 0"
slexe   "update t1 set c1 = substr(c1,-4) || '-03-' || substr(c1,-8,2) where instr(c1,'March') > 0"
slexe   "update t1 set c1 = substr(c1,-4) || '-04-' || substr(c1,-8,2) where instr(c1,'April') > 0"
slexe   "update t1 set c1 = substr(c1,-4) || '-05-' || substr(c1,-8,2) where instr(c1,'May') > 0"
slexe   "update t1 set c1 = substr(c1,-4) || '-06-' || substr(c1,-8,2) where instr(c1,'June') > 0"
slexe   "update t1 set c1 = substr(c1,-4) || '-07-' || substr(c1,-8,2) where instr(c1,'July') > 0"
slexe   "update t1 set c1 = substr(c1,-4) || '-08-' || substr(c1,-8,2) where instr(c1,'August') > 0"
slexe   "update t1 set c1 = substr(c1,-4) || '-09-' || substr(c1,-8,2) where instr(c1,'September') > 0"
slexe   "update t1 set c1 = substr(c1,-4) || '-10-' || substr(c1,-8,2) where instr(c1,'October') > 0"
slexe   "update t1 set c1 = substr(c1,-4) || '-11-' || substr(c1,-8,2) where instr(c1,'November') > 0"
slexe   "update t1 set c1 = substr(c1,-4) || '-12-' || substr(c1,-8,2) where instr(c1,'December') > 0"
? gs
SUB sl(sql AS STRING)
slSelAry sql,sArray(),"Q9"
gs+= JOIN$(sArray(),$CR) + $CR + $CR
GLOBAL gs AS STRING
FUNCTION PBMAIN ()
KILL    "junk.db3"
? gs
Fredrick Ughimi
CJ,
You are a genius!
GLOBAL gs AS STRING
FUNCTION PBMAIN ()
sl      "select rowid,Date from tblSalesOrder"
slexe   "update tblSalesOrder set Date = substr(Date,-4) || '-01-' || substr(Date,-8,2) where instr(Date,'January') > 0"
slexe   "update tblSalesOrder set Date = substr(Date,-4) || '-02-' || substr(Date,-8,2) where instr(Date,'February') > 0"
slexe   "update tblSalesOrder set Date = substr(Date,-4) || '-03-' || substr(Date,-8,2) where instr(Date,'March') > 0"
slexe   "update tblSalesOrder set Date = substr(Date,-4) || '-04-' || substr(Date,-8,2) where instr(Date,'April') > 0"
slexe   "update tblSalesOrder set Date = substr(Date,-4) || '-05-' || substr(Date,-8,2) where instr(Date,'May') > 0"
slexe   "update tblSalesOrder set Date = substr(Date,-4) || '-06-' || substr(Date,-8,2) where instr(Date,'June') > 0"
slexe   "update tblSalesOrder set Date = substr(Date,-4) || '-08-' || substr(Date,-8,2) where instr(Date,'August') > 0"
slexe   "update tblSalesOrder set Date = substr(Date,-4) || '-09-' || substr(Date,-8,2) where instr(Date,'September') > 0"
slexe   "update tblSalesOrder set Date = substr(Date,-4) || '-10-' || substr(Date,-8,2) where instr(Date,'October') > 0"
slexe   "update tblSalesOrder set Date = substr(Date,-4) || '-11-' || substr(Date,-8,2) where instr(Date,'November') > 0"
slexe   "update tblSalesOrder set Date = substr(Date,-4) || '-12-' || substr(Date,-8,2) where instr(Date,'December') > 0"
? gs
This is for the keeps.
Thanks a million!
July 04, 2018, 04:31:12 PM #12 Last Edit: July 04, 2018, 07:53:01 PM by cj
You are welcome.
Method2 creates a date column recordset of rowid,date then loops through each element and updates the associated row with new date.
GLOBAL gs AS STRING
FUNCTION PBMAIN ()
CreateTestDatabase "Method1 Update by the month"
Method1
CreateTestDatabase "Method2 Loop through recordset"
Method2
? gs
SUB Method1 'Scan for dates in a month, then update. Perform once for each of the 12 months.
slOpen "junk.db3"
slselAry "select rowid, c1 from t1",sArray(),"Q9c"
gs+=JOIN$(sArray(),$CR) + STRING$(3,$CR)
slClose
SUB Method2  'Create recordset of dates. Update date column from first to last record.
LOCAL eleNum,num AS LONG,sNewDate,sArray() AS STRING
DIM sMonthName(1 TO 12) AS STRING
DIM sMonthNum (1 TO 12) AS STRING
ARRAY ASSIGN sMonthName() = "Jan","Feb","Mar","Apr","May","Jun","Jul","Aug","Sep","Oct","Nov","Dec"
ARRAY ASSIGN sMonthNum () = "01", "02" ,"03" ,"04" ,"05" ,"06" ,"07" ,"08" ,"09" ,"10" ,"11" ,"12"
slOpen "junk.db3"
slSelAry "select rowid,c1 from t1",sArray(),"Q9c"
FOR eleNum = 1 TO UBOUND(sArray)
  FOR num = 1 TO 12
   IF INSTR(sArray(eleNum),sMonthName(num)) THEN
    sNewDate = RIGHT$(sArray(eleNum),4) + "-" + sMonthNum(num) + "-" + MID$(sArray(eleNum),LEN(sArray(eleNum))-7,2)
    'slexe "update t1 set c1 = '" + sNewDate + "' where rowid =" + STR$(eleNum) 'wrong 7/4/18 3:45 PM CST
    slexe "update t1 set c1 = '" + sNewDate + "' where rowid =" + STR$(VAL(sArray(eleNum)))
    EXIT FOR
slSelAry "select rowid, c1 from t1",sArray(),"Q9c"
slClose
SUB CreateTestDatabase(sTitle AS STRING)
KILL "junk.db3"
'IF ERR = 0 THEN ? "Kill junk.db3":ERRCLEAR ELSE ? "Kill error" + STR$(ERRCLEAR)
gs+= sTitle + $CR + JOIN$(sArray(),$CR) + STRING$(2,$CR)
slClose
GLOBAL gs AS STRING
FUNCTION PBMAIN ()
Method1
Method2
? gs
slOpen "junk.db3"
slClose
slOpen "junk.db3"
  FOR num = 1 TO 12
    slexe "update t1 set c1 = '" + sNewDate + "' where rowid =" + STR$(VAL(sArray(eleNum)))  '3:45 PM CST 7/4/18
    EXIT FOR
slClose
KILL "junk.db3"
slClose
Fredrick Ughimi
July 05, 2018, 02:47:20 AM #13 Last Edit: July 05, 2018, 06:26:15 PM by Fredrick Ughimi
Hello CJ,
Method 2 is another beauty. Goes to show how using logic can solve problems. I wonder why PowerBASIC is not out there in the public domain like other major languages.
Thank you, CJ.
